Motorino has the Ruima jug I am using at a better price than Jiangwayne. That jug runs like a raped ape w/o the stroker, and needs very little tweaking. You can install it w/o going into the boost port mods, and it will preform as well or better than the Malossi. The reason is the torque from the xtra cc's. I thought the Peop. case was the same as the zx but found it is different. My thinking is if the studs are the same, and the liner fits GO RUIMA. I can/will walk you thru it, and you will have a 55-60mph peop. with more torque than you would believe. I bought Aeromyst's zx engine, and it will be here by Monday afternoon. I can measure it all out for you, and see if it will fit the jug you have now (compare the 2). Or here comes "Son of Sid"
