Author Topic: ..motorio 48mm kitting..  (Read 23265 times)
Re: ..motorio 48mm kitting..
« Reply #60 on: February 16, 2012, 03:55:43 AM »
Right on Bro! Their finicky little buggers... Cheaper than a street rod tho. I found it easiest to table clamp the head/cyl. to a drill press, and use 3-4 different steps up w/ the drill bits. The sizes are close enough if the bit can almost twist in by hand. That way the factory drilled holes are  the guide. Wouldn't wanna try it w/ a hand drill tho.
« Reply #61 on: February 16, 2012, 11:44:24 AM »
Experience is everything huh zombie?
..i had some good advice from great friends...the whole experience has been great so far...
..of course, i aint got her out on the street yet...lol..
..if i can get a few thousand kms outta this cheap-ass kit, i reckon i'll be happy   :)
« Reply #62 on: February 16, 2012, 01:51:41 PM »
"..if i can get a few thousand kms outta this cheap-ass kit, i reckon i'll be happy  "
That's the whole point right there!
« Reply #63 on: February 16, 2012, 02:07:06 PM »
...on another note, we put a Technigas NEXT pipe on my buds ppl yesterday, looks great and sounds AWESOME!!..
..oem carb, airbox and a 90 main jet...
..he told me this morning, that at @ 50+ indicated, the engine starts "popping"..
..i allowed how that's probably lean, and we need to increase jet size to maybe a 95...
..that sound about right?
« Last Edit: February 16, 2012, 02:08:47 PM by wordslinger »
Areomyst
  • Scootin' America!
« Reply #64 on: February 16, 2012, 08:44:29 PM »
What year is your buddy's People?  Has rev-limiter been disabled?
Upjetting is important, yes. :)
~Josh
« Reply #65 on: February 16, 2012, 08:49:39 PM »
If the popping is thru the pipe it is lean.  50+ sounds like wot so the needle would have NO effect. If he is centered w/ the needle clip then a 95, and lean the clip for midrange. He may start going rich in the mid (w/ the 95) if the needle is not leaned to compensate.
I've told my real life friends to stay away because my forum friends are soooooooooo much better. XOXOXO (gay huh) Bring on the scootgirl!
« Reply #66 on: February 16, 2012, 08:49:56 PM »
..its an 02, has the bronze carb with the bigger slider...
..completely derestricted, malossi multivar with 8.5 oem rollers, 743 belt, oem clutch with unrestricted driven pulleys..
« Reply #67 on: February 16, 2012, 08:53:18 PM »
..that's what i thot as well...
..i sold him this scoot, its the one that tried to kill me back in november..we call her christine..evil fukn cyclops bitch...
..so, i know that the needle has not been touched..
« Reply #68 on: February 16, 2012, 08:55:03 PM »
..couldnt prove that by your "Ethanol" thread..lmo!!!
« Reply #69 on: February 16, 2012, 09:00:15 PM »
Forgot... The reason the expansion chamber pipe requires richer jetting is the OEM type pipes create alot of back pressure to stop the incoming fuel charge from dumping out the pipe w/ the burnt gases. The Exp. pipe is designed to have almost zero back pressure, and uses sound waves to push the fuel charge back into the jug thru the exhaust port (not atmospheric pressure). So with better efficiency in removing the charge you need to compensate by adding a richer charge, as the gases being pushed back in (from an Exp. pipe) are diluted w/ the burnt gases.
 Just kinda paraphrased that but I know you get it.
« Reply #70 on: February 16, 2012, 09:02:59 PM »
I get naked, and put steel wool in my butt before posting on that thread! "I'm Feeling Hot,Hot,Hot!"
« Reply #71 on: February 16, 2012, 09:05:31 PM »
..yes i do...thank you very much!..this was my first pipe upgrade...
..we have free-flow filters in transit, so there'll be more jetting to come..
..i also have the techni pipe to install on my s9 at some point, but imma wait on that for a while..she runs so good oem..lol..
..yeah, wait a while.........or will I?.........
Areomyst
  • Scootin' America!
« Reply #72 on: February 16, 2012, 09:20:06 PM »
What?!?  I thought I was the only one that...  Nevermind.
I'm starting to wonder about my internet buddies. :P
Wordslinger, how's the takeoff on the People?  I've always found the People to be tougher than normal to get dialed in with an expansion chamber on the stock cylinder.  I blamed it on the gearing since it has the 16" rear wheel...
~Josh
« Reply #73 on: February 16, 2012, 09:25:20 PM »
That... WHAT J.?
« Reply #74 on: February 16, 2012, 09:35:08 PM »
..it had awesome, instant take-off..no lag at all till the pipe..
..now, he's reporting a bit of initial lag, but that after it "latches in" it's like a rocket..
..going to try 8 gram rollers (in transit)..to see if that takes care of the lag...
« Last Edit: February 16, 2012, 09:36:52 PM by wordslinger »
