Author Topic: ..motorio 48mm kitting..  (Read 23268 times)
Re: ..motorio 48mm kitting..
« Reply #75 on: February 16, 2012, 09:40:55 PM »
Stiffer Contra spring to hold the "gear" longer.
« Reply #76 on: February 16, 2012, 09:41:53 PM »
W/ the pipe, and lighter rollers he will pass the pipe quickly, and fall flat again.
« Reply #77 on: February 16, 2012, 09:45:21 PM »
..the tech next pipe came with 7 gram rollers...lol..
...put'm in the box with the rest of the old/new un-needed bits...
« Reply #78 on: February 16, 2012, 09:50:10 PM »
..oh yeah, i forgot to mention that i put a malossi blu (1500?) a few weeks back, which did indeed get it to the point of instant takeoff..
..i have a malossi MHR red in transit...
« Reply #79 on: February 16, 2012, 10:33:30 PM »
Well then it may be a flat spot in the jetting/wrong plug gap. Try adjusting the gap (bigger/smaller).
« Reply #80 on: February 19, 2012, 05:08:27 AM »
..like that pipe..lol..
« Reply #81 on: February 19, 2012, 05:40:55 AM »
should i further index my oil pump with the added displacement?
« Reply #82 on: February 19, 2012, 05:48:33 AM »
..see that spec of aluminum?
...I HADDA HELLUVA TIME CLEANING THE CASE!!...
     :o
« Reply #83 on: February 19, 2012, 05:54:22 AM »
..dunno what this port does, on the piston..but i cleaned it up...
« Reply #84 on: February 19, 2012, 05:56:08 AM »
..this shoulda tipped me off about the jug hitting on the left...see those humps?
« Reply #85 on: February 19, 2012, 05:58:52 AM »
..had to clean up the jug, and the top hump...
..good thing i noticed it before i fired it...
« Reply #86 on: February 19, 2012, 06:00:12 AM »
Beautiful Schtuff Bro! BUT ABORT THE OIL PUMP! JiangWayne's Wayne explained these kits need 37:1 FULL Synth from the start. More than that, and  the oil takes up jet space. The pump has varying oil and plays hell w/ combustion temp.. When you throttle down the engine is running Max rpm's at a 100:1 ratio from the pump but 37:1 premix I stubbornly tried the pump any way but soft seized at least 4=5 times. Adding oil to the tank w/ the pump is even leaner Because the oil in the tank takes up jet space leaning the fuel to air ratio even more. I just carry a bottle of 2t, and some 1oz cups in a clean bag. Just pull the pump, take/grind off the gear, and put it back in
« Reply #87 on: February 19, 2012, 06:01:55 AM »
..i think that's been my problem 2t child...
« Last Edit: February 19, 2012, 06:03:45 AM by wordslinger »
« Reply #88 on: February 19, 2012, 06:02:28 AM »
..no sh**?
« Reply #89 on: February 19, 2012, 06:05:35 AM »
Next time you split those cases, and remove ALL the sharp corners, and flatten those spots where it hit. The smoother EVERYTHING is in there the more torque/rpm's you can get. That's all the stuff I polished     mirror
