Author Topic: ..motorio 48mm kitting..  (Read 23258 times)
Re: ..motorio 48mm kitting..
« Reply #90 on: February 19, 2012, 06:07:24 AM »
For real... Don' have to buy a plug that way
Just pull the pump, take/grind off the gear, and put it back in
..no sh**?
« Reply #91 on: February 19, 2012, 06:08:42 AM »
..i thot about that..but at the time, i was more concerned with getting out the dumb sh**..from the melted piston...
..think i got everything pretty damned clean...
..worked onnit for hours..ask batman...lol..
..he patiently coached me thru a bunch of this project..
..where is he......
« Reply #92 on: February 19, 2012, 06:10:39 AM »
..just so happens, i have an old, worn oil pump that dont need its gears anyway...
..how much per gallon should i mix with this 75cc, and what's the best sh**??
« Reply #93 on: February 19, 2012, 06:14:44 AM »
..dunno how this pic represents, but i hand-polished everey port edge...for smoothness...
..again..for hours....
       ;D
« Reply #94 on: February 19, 2012, 06:27:31 AM »
That's all the work that will make it last. I've been using Golden Spectro Synth for 46 years. For easy #'s just mix it 2oz per gallon. That's 32:1. You can order it in cases for about 6 bucks a bottle. They are the best imho
http://www.spectro-oils.com/?p=248
« Reply #95 on: February 19, 2012, 06:32:04 AM »
..i gotta dealer just down the road that sells that..
..its actually where i bought my last helmet..cooollll....
« Reply #96 on: February 19, 2012, 06:43:41 AM »
That's awsome. You might see if he will give a case discount cause it can sell for 12.99 qt. The MX Synth is the same oil as the scooter oil w/ higher octane/burn temp. almost too much for scoots. You just need to repack the silencer more often cause it leaves more oil. OR remove/empty the silencer. The later will require (1) clip richer in the carb. How did the last piston in there die?
« Reply #97 on: February 19, 2012, 06:46:14 AM »
..that faulty oil pump i mentioned before..
..it leaked, and i didnt notice it before it was too late...
..remember, i ride 40 miles a day...lol...pretty much wot all the way...
« Reply #98 on: February 19, 2012, 06:49:35 AM »
...no, wait..wrong scoot..that was christine...
..thisn i just missed the WOT jetting, i think...
..oem, with k&n filter, and a 748 belt this 02 would peg the speedometer easily...
..maintain 45-50 on the flats...easily...
« Reply #99 on: February 19, 2012, 06:51:48 AM »
..thats high, but you pay for what you get when buying lubes....
« Reply #100 on: February 19, 2012, 06:57:53 AM »
..01 ppl indicates 60mph...
« Reply #101 on: February 19, 2012, 07:02:51 AM »
« Reply #102 on: February 19, 2012, 07:08:19 AM »
That's hot sh#t! The new kit will give MAYBE 5mph above that from the xtra cc's but it will get their alot quicker. Get into gears for it to take advantage of the torque gain. Then you may have a 55-60mph cruise, and 70top. Alot safer than a ZX too!
« Reply #103 on: February 19, 2012, 07:08:55 AM »
..the dome of the piston was not burned, not at all, nowhere around its perimeter...rings failed top and bottom of cylinder orientation...underneath side of piston dome was "cooked" black oil...cylinder scored badly on top and bottom...
« Reply #104 on: February 19, 2012, 07:13:59 AM »
..fuzzy pic...lol..
