Did you miss your
activation email
Scooters - 50cc
Dowel pin locators
Topic: Dowel pin locators (Read 934 times)
Scuzz
Newbie
Dowel pin locators
February 09, 2012, 08:36:12 PM »
I have ordered new dowel pin locators and I need to know where they go. Any help would be great.
You never know do ya!
Close enough to get the idea!
Re: Dowel pin locators
February 10, 2012, 02:53:25 AM »
Why did you order them? They install (2) between the Cylinder base, and the engine case . There are two more between the Cyl., and the Cyl. head. There are two holes in each part that have larger holes to accept them.
undead primate
February 10, 2012, 12:34:26 PM »
..now, why would you do that??
Scuzz
Newbie
Reply #3 on:
February 10, 2012, 01:05:11 PM »
Because some were missing...
undead primate
Reply #4 on:
February 10, 2012, 01:53:36 PM »
...okay, i guess i'm confused...
..if you know that they are missing, then why you need to ask where they go??
Scuzz
Newbie
Reply #5 on:
February 10, 2012, 01:56:32 PM »
I just needed to double check..
undead primate
Reply #6 on:
February 10, 2012, 01:59:24 PM »
..none of my ppl engines have locators....i've had all 3 of them apart..
..the holes were not oversized for them either...
Shaka
Reply #7 on:
February 10, 2012, 05:24:54 PM »
I'm pretty sure there are a couple on the CVT cover on my ZX as well.
undead primate
Reply #8 on:
February 10, 2012, 05:39:44 PM »
..word up shaka!!!
..long time no see!!!
..yup, all my cvts have them..
Reply #9 on:
February 10, 2012, 11:58:44 PM »
What's shakin' Shaka? Good to "see" you. The 2t's generally do not use them because the Cyl. liner fits the case tight enough to line them up. Same for the bolts/studs for the head. Most 2t's hav the piston at or below the top of the Cyl. so locator's are not required. I mentioned them to Slinger because of the jug I thought was using. My piston in the ruima is actually 1.5mm above the deck so a misaligned head will stop it dead. They are used in 4t's because of the multiple parts involved. Too much room for error. They will only fit in two of the holes in each piece Scuzz
Back
