Author Topic: belt or clutch spring.  (Read 10273 times)
Re: belt or clutch spring.
« Reply #15 on: February 12, 2012, 12:42:09 AM »
OK now your teasing me .thats something this red neck would do.lol
« Reply #16 on: February 12, 2012, 01:53:25 AM »
Fir reel !
« Reply #17 on: February 13, 2012, 12:01:46 AM »
Fir reel !
ya fir reel... from the looks of your pic you are off to a good start.just need to find away to weld a seat to it.
« Reply #18 on: February 13, 2012, 01:32:57 AM »
I am a boat builder. A seat will be a walk in the park. That is the 139QMB that I installed the 50mm BBK on a few weeks ago. 53mph on 10" wheels. I'll be wearing the mattress soon.
« Reply #19 on: February 13, 2012, 01:53:21 AM »
put a seat like this on that would take much and you can sit low in it.
« Reply #20 on: February 13, 2012, 02:37:53 AM »
Actually that style is what I had in mind. I already lowered the scoot 1 1/2" front, and rear. I have a welder buddy coming Thurs to do some work on another project so I am going to lengthen it 4 1/2". Get that Vato Loco look going. The frame is done in Awl Grip oyster white, so I figure black for the bolt on's. Twin head lights, brake, and blinkers. That is all I need. Can't decide between turned down drag bars or ape hangers yet tho.
http://t2.gstatic.com/images?q=tbn:ANd9GcS1zI6ZqpxbmTlIURW02Khbzwh639jd0w9n6ckOsvtnwhXx45qexg
« Reply #21 on: February 13, 2012, 03:34:00 AM »
what kind of front end are you going with. and for a gas tank a small keg would look sweet.
« Reply #22 on: February 13, 2012, 04:27:44 AM »
Never thought about the tank. Jug would be cool. Just gonna keep the stock set up in front. This thing was $150.00 soooo Not too worried about it. I just made a bet w/ Jpres. if he takes it. Check it out on the Eth. chanel
OregonDad
« Reply #23 on: February 13, 2012, 07:33:01 AM »
The belt is measured in mm not inches. It should be replaced if it is more than 1 year old. They don't stretch enough to cause what you describe but they do get thin enough to reduce speed. This will NOT happen all of a sudden. more of a gradual loss.
So it would be a good idea to get the belt replaced on the 2008 Agility 50 with 6050Km as soon as possible?
Any good places to order the belt here in the states?
« Reply #24 on: February 13, 2012, 02:08:00 PM »
try monsterscotterparts .com
« Reply #25 on: February 13, 2012, 05:54:36 PM »
Ok took scoot apart this morning and found a air leak in the carb by the elc. choke the o ring was toast.
replaced that. cleaned up the carb and she runs realy good. after a 5 mile test drive and all the rpms are doing great I can tell I stell need a belt. I can now feel it kick in after I throtle up. its like its sliping then it just gos.And when I kick start it It slips also.
OregonDad
« Reply #26 on: February 13, 2012, 08:59:55 PM »
I would appreciate pics of the belt assembly and where a new drive boss fits in.  Others have mentioned removing a washer next to the original drive boss.  Where is that located?
« Reply #27 on: February 14, 2012, 01:16:27 AM »
Different scoot but all the same. There are about 100 more vids there
« Reply #28 on: February 14, 2012, 02:39:18 AM »
the drive boss is behind this nut.
« Reply #29 on: February 14, 2012, 12:56:29 PM »
..yo blue...you need a belt, bro!!!
