Author Topic: My Kymco Agility 50 Starting Problem??  (Read 35447 times)
thebatman
Re: My Kymco Agility 50 Starting Problem??
« Reply #45 on: March 08, 2012, 10:53:09 PM »
Every post helps (except most of mine, and all of Axy's)
LMAO.. :D  :-X
"THE BAT"MAN...
Says:
Peters
  • In Glock I Trust
« Reply #46 on: March 08, 2012, 10:54:40 PM »
 :D :D :D
+1 for zombie
*2001 ZX-50 beater
« Reply #47 on: March 08, 2012, 11:13:44 PM »
Yeah I know
thebatman
« Reply #48 on: March 08, 2012, 11:22:30 PM »
That wasn't the same this 2nd time w/o good 'ol Bob..  ;)  :D (I'd like them girls myself.. :D)
"THE BAT"MAN...
Says:
« Reply #49 on: March 08, 2012, 11:27:52 PM »
Drew is morphing into Bob. That boy has REAL issues...
micoman
« Reply #50 on: April 12, 2012, 09:28:40 PM »
I have my Kymco back now after the starter relay replacement and it has been better but not great! Starts ok about 90% of the time.
If I get it to start on the first try its fine, its just if I dont it then has troubles?
It had not been run for a few days and then I went out on a hot sunny day to start it. It did not start on the first attempt so I gave it a little longer before flicking the throttle a little but still no good? I then needed to run it for a good 5 seconds and then flick the throttle before it finally started?
I also noticed that when it has just started, if I try and open the throttle it sounds like its going to stall?
The trouble is when I leave it with the dealer and they test it, it starts fine? I'm starting to think its just me? I am a left hander and usually hold the left brake to start it as holding the right is a little awkward for me. I have now switched back to the right brake as it seems to help with starting.
Did I mention before the oil looks a bit high on the dip stick, could that be a problem?
Once its running for a while it runs well though.
I'm trying to sell it at the moment so its not going to look good if it does not start first time!!
Any advise appreciated:)
« Reply #51 on: April 13, 2012, 12:15:58 AM »
Use a baster/syringe to remove the excess oil. It can cause a Hydro lok. You may just need to crank the starter a few seconds longer. They NEED rpm's to fire. Low rpm=low spark. Just crank till it is Really running.
