Author Topic: PLEASE HELP!!!!! NOOB IN NEED  (Read 3691 times)
xhellmanx
Re: PLEASE HELP!!!!! NOOB IN NEED
« Reply #15 on: February 24, 2012, 08:03:25 AM »
Just cleaned the spark plug and air filter. Now just sitting on the stand and putting it on full throttle it cuts in and out. Like goes full power then cuts down then picks back up.
« Reply #16 on: February 24, 2012, 10:45:16 PM »
Just pulled the scooter apart. Would the fact that the air filter foam having oil al over stopping air flow to the moter cause this problem?
That will do it.
« Reply #17 on: February 24, 2012, 10:58:15 PM »
The carb. may need cleaning/adjusting. If it is jumping around rpm's you may also have a vacuum leak somewhere. If your intake filter was clogged the scoot will try to pull air elsewhere. This may have sucked out a worn seal, or the coupler that mounts the carb to the engine. Sounds like your scoot needs a through going over to know what is happening. Do you have a scooter shop anywhere near you. Some shops will "hook you up" if you mention the forum, and "advertise" for them.
Jpreston has a running scoot, and he still wonders what the hoke under the seat is for.
xhellmanx
« Reply #18 on: February 25, 2012, 09:29:36 PM »
Mate I cleaned the spark plug and pulled the head thing off that the spark plug is screwed into. Wire brushed all that up. Cleaned the foam from the air filter and also put a hose back on that fell off a while. This hose is about 8 cm long and 3 cm in diameter. I think it's some sort of air hose. Anyways put all the bits back together and scooter is running smooth as again!!! It's fixed. For now anyways. Thank u so much for all ur help. I really appreciate it. Cheers
« Reply #19 on: February 26, 2012, 12:15:21 AM »
that's terrific... Cant say I'm not surprised too
