Did you miss your
activation email
Technical | How To
Question about a People 150
Topic: Question about a People 150 (Read 730 times)
Jethronomics
Newbie
February 24, 2012, 09:26:36 PM »
Hello everyone,
I have a People 150 and it runs rough from dead stops to 5 to 10 mph. after that it is extremely smooth.
Anyone know what's wrong with it or what I can do to take care of the problem?
Thanks!
Cortez
Re: Question about a People 150
February 24, 2012, 09:55:41 PM »
Pull in both brakes, open up the throttle all the way, let go of the brakes just slightly, enough to
let the scooter start moving, but at walking pace. The idea is to get the clutch slipping and burn
it up a bit.
Repeat a few times.
That'll fix it.
'08 FZ6n S2 ABS
Jethronomics
Newbie
February 24, 2012, 10:52:42 PM »
Thanks, I'll try it out. A mechanic recommended to me over the phone to take apart the crank start and clean it. I'm guessing your telling me to do the same thing in a dfferent way.
You never know do ya!
Close enough to get the idea!
Reply #3 on:
February 24, 2012, 11:13:15 PM »
If you mean the engine is mis firing (rough) then the idle mix screw may need a turn or so. Try turning the MIX screw one way or the other (1/2 turn at a time). Wait a few seconds, and note any changes in rpm. You'll want the highest rpm's from this screw. Once you get them turn 1/4 turn clockwise. Then you can adjust your idle speed screw to get the recommended idle rpm
Ps... In My Humble Opinion... DON'T burn the clutch. It does more long term harm than short term gain. If you suspect the clutch... SERVICE it.
Clean the air filter, and change the spark plug too!
Reply #4 on:
February 24, 2012, 11:15:13 PM »
Forgot to mention valve adjustment. These need constant checking. Do you hear any ticking sound? Or a popping thru the exhast/intake?
Back
