Author Topic: people 300 valve adjust  (Read 2140 times)
iker
  • , 2007 kymco people s125
« on: February 25, 2012, 12:41:56 AM »
900 miles and i checked the valves just to be sure all ok.
remove engine cover, seat and with a small screwdriver snap off front cover ,just take it easy. now the valve cover is right there. 4 bolts, 1 hose and loosen bolt on side.
find top dead center, remove cover on alt. cover ,use 19mm scoket to turn engine over - clockwise. check valves with .004in or .1mm. mine were all ok except 1 intake valve was tight - 003, corrected to .004in. easy to do.
also checked plug. it was very loose finger tight .color was fine , installed and tightened . all done ,next check at 3000 miles . see yea, ike
2007 kymco people s125 aka - lit red
2011 vespa gts 300 super aka - tin man
boo
Re: people 300 valve adjust
« Reply #1 on: February 25, 2012, 11:41:44 PM »
From your post, it sounds like the valves are pretty easy to get to.
Glad to hear that.
When you install spark plugs in those aluminum heads, it is always a good idea to use some anti seize compound on the threads.
Thanks for the information.
300GTI black
Pro 2A - member GOA & NRA
