Author Topic: Starter motor wont stop  (Read 1954 times)
Scuzz
« on: February 28, 2012, 06:33:50 PM »
So the startor motor stays on even if the key isn't in unless I disconnect it
Re: Starter motor wont stop
« Reply #1 on: February 28, 2012, 08:14:19 PM »
..your starter relay contacts are stuck closed...tap on it a lil...
..and go ahead and order you a new one..
« Reply #2 on: February 28, 2012, 09:37:40 PM »
« Reply #3 on: February 28, 2012, 10:31:45 PM »
x 2 hit it.
Scuzz
« Reply #4 on: February 29, 2012, 01:00:45 AM »
Where is the starter relay?
« Last Edit: February 29, 2012, 01:38:35 AM by Scuzz »
« Reply #5 on: February 29, 2012, 03:29:33 AM »
Follow the +12 volt lead backwards from the starter motor. It'll lead you right to it. It is possible the starter switch contacts are stuck too. so check that as well. Do you have a test light? That will make quick work of trouble shooting once you get to the relay.
Scuzz
« Reply #6 on: February 29, 2012, 04:24:29 PM »
OK that worked. Cheers!
« Reply #7 on: February 29, 2012, 08:04:46 PM »
And "If the lights don't work just jiggle the cord"
« Reply #8 on: February 29, 2012, 08:42:36 PM »
..yeah...been waitin' on that one z-man!
« Reply #9 on: February 29, 2012, 08:44:44 PM »
You could almost use it on every post!
« Reply #10 on: February 29, 2012, 08:50:21 PM »
..i wanna be moddin' somethin'..
..got to be moddin' somethin'..
..u must be moddin' somethin'..
..u know u wanna be moddin' somethin'!
...wee-hee!...
« Reply #11 on: March 01, 2012, 02:20:38 PM »
if it was a 2 stroke you could just push it and jump on and go ...........lol
« Reply #12 on: March 01, 2012, 11:41:43 PM »
"if it was a 2 stroke you could just push it and jump on and go ...........lol"
How are you doing Blue? Feeling OK? You SURE!?
I'm starting to worry 'bout you Bro!
A warm glass of milk and a nice long nap will get you back in shape!
Peters
  • In Glock I Trust
« Reply #13 on: March 02, 2012, 02:34:14 AM »
I think I burnt up my starter ;D. I burnt through the wire on the hot exhaust(wasn't routed properly). Fixed the wire but still no beans. I can hear the relay. I've been meaning to pull the starter off and test it. Guess I really don't have to pull it off. I'm just lazy.
Is there any other fuses other than the one on the battery?
« Last Edit: March 02, 2012, 02:38:07 AM by Peters »
*2001 ZX-50 beater
« Reply #14 on: March 02, 2012, 05:05:43 AM »
More likely you fried the relay. It can still click, but have NO contact left inside. Use a Bosch 30 amp. They're cheaper, and at the hardware store.
