I just installed a 70cc kit on it, Air filter, Fuel filter [on top of the stock]
Cleaned the carb out, adjusted idle jet, adjusted the float
It idles perfectly, sounds good, Revs up fine but when the clutch engages and its starts to move it first runs fine then when you get to higher rpms dies out [as if the carb is dirty again] Sounds to me like a high speed problem.
People 50 2 stroke, running a bit rich b/c of break in
