Author Topic: Headlights Out Super 8 50 2t Need Help  (Read 2003 times)
Pimpy1
  • Mo Hoes Power
« on: March 03, 2012, 11:40:59 PM »
Lights went out. Tried 2 new sets of HS1 35/35 bulbs with no luck. Had the bulbs both light for just a second a few times then go out.
Checked all fuses in battery area and all wire connections I could find. Will not work in high or low beam. Turn and brake lights all work fine.
Thanks for any help. I tried all the light info I could find on the sight with no luck. This is a new 2011 scoot.
2011 Kymco Super 8 2t
2006 Kymco People 250
Re: Headlights Out Super 8 50 2t Need Help
« Reply #1 on: March 03, 2012, 11:54:31 PM »
..sounds like your rectifier ain't rectifying...get you a new one!
peace
« Reply #2 on: March 04, 2012, 12:30:31 AM »
Have to do it... Just jiggle the cord!
(inside joke) Try wd40 type stuff in the light switch. They get corroded all the time. The light is ac fired I think so the rect. wont be involved if that is the case. If it is dc fired then maybe... Try the switch first tho
Pimpy1
  • Mo Hoes Power
« Reply #3 on: March 04, 2012, 12:51:06 AM »
Thanks. Will open up the switch tomorrow. Scooter is 2 weeks old so I hope it's not rusting up already.  all other lights are working and it is charging ok. I hope a short didn't fry the rectifier. Not having a good start as a new scooter owner.
« Reply #4 on: March 04, 2012, 02:16:45 AM »
2 weeks? Take it to the dealer... No way it corroded. Unless you live on a volcano. (active)
« Reply #5 on: March 04, 2012, 08:00:42 PM »
..i burned three headlamps...taillamps on my 01 ppl before i figured out the rectifier was bad...
« Reply #6 on: March 04, 2012, 11:52:58 PM »
I just forget which ones have which circuit. They swap them around alot from model to model
warriorboxerdog
« Reply #7 on: March 22, 2012, 06:09:10 AM »
I had the same problem with my super 8 2T. Bothe headlights just stoped working, There is a box under the plastic, looks like a cdi. That is the headlight controller wox what i did is unplug it jumed the 4 prong blug and bame lights are back on. I tried to call the dealer and get them to fix it but they were assholes. So far no adverise affects and been running it this way for a week now. The thing I like about it is the head lights don't dime at idle anymore and they come on as soon as you turn the key to the on position. I'm going to switch out my other bulbs to l.e.d. bulbs to reduce the amount of current used while the bike is running. There are videos outhere to show you how to do this. I tinned my wires with soldier before using the to mke tiny jumpers
super 8 nate
« Reply #8 on: March 22, 2012, 11:08:22 AM »
got the samething going on. I'm going to have to mess with it some more it looks like. I got a recitfier but the fittings aren't the same even though they are supposed to be for all gy6 scooters.
