Author Topic: idles but wont respond  (Read 4541 times)
sthomas904
« on: March 11, 2009, 12:05:38 AM »
engine idles and when I give it gas it doesn't respond  ??? i checked the throttle cable and its working its like the gas just wont go into the intake any thoughts?
harleydude
Re: idles but wont respond
« Reply #1 on: March 11, 2009, 09:23:35 PM »
Might check the fuel filter and see if it is full or not.  If it isn't, either the filter may be clogged or the fuel pump has gone bad. --- Could be a carburetor problem too but check the fuel system out first.
sthomas904
« Reply #2 on: March 11, 2009, 11:33:43 PM »
well today i took the intake off and behold someone used rtv stuff to make a gasket, now i know you can do that with antifreeze and oil but gas  ??? i dont know
yajblackburn
  • 2004 ZX50, 2000 People 50, 2002 Yup50
« Reply #3 on: March 12, 2009, 04:24:32 PM »
I actually regularly use the rtv silicone to make gaskets for the intake manifold and the cylinder gasket.  I make sure not to glob it on and I always wipe the edges where it counts so nothing will get clogged.  My advice to you would be to go through your fuel system again and replace the fuel lines, fuels filter, clean carburetor, draing and clean the fuel tank and clean or install a new spark plug.  The fuel systems on these bikes are super finikey.  The smallest thing will screw up everything.  There is no fuel pump so you don't have to worry about that.  It's a gravitational/vacuum operated fuel system.  A word of advice is you can't clean these fuel systems enough, I've had to do this several times in order for some bikes to work properly.
sthomas904
« Reply #4 on: March 15, 2009, 04:08:14 PM »
well i found out somthing interesting today... with the kill switch on it cranks and runs but when you give it gas, nothing. with the kill switch in the off position it runs somewhat like it should  >:(  i posted a video
sthomas904
« Reply #5 on: March 19, 2009, 11:05:48 PM »
ok i replaced the autocock,fuel line fuel filter and ignition coil.cleaned the fuel tank out. it ran for a little bit then at about 30mph it quit responding and shut down, would the cdi have anything to do with this? I was told by a parts guy that this particular scooter always had problems with these. its a 2000 kymco zx50 2stroke
« Last Edit: March 19, 2009, 11:07:35 PM by sthomas904 »
FinInGermany
« Reply #6 on: March 23, 2009, 01:59:42 PM »
Does the problem only kick in when the engine's warm, or also when it's cold? I had a similar problem recently with a warm engine. Turned out that my variomatic weights were shot. Surprised the hell out of me, as I thought it wouldn't have responded at all with the weights in the state they were.
Good luck.
Fin.
sthomas904
« Reply #7 on: March 23, 2009, 04:40:40 PM »
well i ordered a new cdi a couple of days ago, i should receive it this week and I will let you know if its fixed
sthomas904
« Reply #8 on: April 09, 2009, 04:07:11 PM »
well i got the new cdi, but i took apart the cylinder head and noticed the metal gasket was bent and had been leaking a little gas out the back corner of the motor, i used the metal gasket and some rtv so hopefully this will fix my problem  ;D
« Reply #9 on: May 07, 2009, 02:00:31 AM »
hi, just a little add on. i have had the same problem with kymco factory cdi units. my scoot would run until warm, and then either die completely or loose power to the point i could only limp home. i have had three in the past year, and am in the process of trying to find a reliable replacement. i have posted this under new racing cdi. the only knowlagable response i have had has been from jiangwayne.com. lyn xu informed me they work with a manufacturer in tiwan that makes a derestricted cdi that has the correct timing curve for the zx/50 super fever. the bad news is it will take 25 days to ship to my address in fla. i will post the results
sthomas904
« Reply #10 on: September 23, 2009, 03:46:21 PM »
Figured it out!! flywheel was so rusted iy was preventing from starting/running right
I know its an old post but i figured i would post my results
« Reply #11 on: September 23, 2009, 09:07:35 PM »
That's what makes the forum work! AWESOME!
Shaka
« Reply #12 on: September 23, 2009, 10:11:46 PM »
I wouldn't have guessed that!  Interesting!
« Reply #13 on: September 24, 2009, 10:38:35 AM »
...wow...that's one for the memory banks...
