Author Topic: stall at idle  (Read 1269 times)
super9-87
stall at idle
« on: March 06, 2012, 04:49:59 PM »
I have a 2005 super9 lc  I picked up 4 700 bucks and it needed tuned so got it done a repable  shop and now it stalls at idle he tells me it might  be my crank bearing  I dont c how that could  happen any idea on how or what it could b
thebatman
Re: stall at idle
« Reply #1 on: March 06, 2012, 06:54:12 PM »
I'm thinking carb issue but i'm no master.....
You can check the crank bearings yourself.....
Remove the cvt cover, var, belt. Try and wiggle the crank in/out... up/down. If you have more than 1mm play, then maybe he is correct.... The other side, remove the water pump and wiggle the crank...
My 1st thought is still carb.. mix screw is off not letting it idle...
Maybe some of the other guys will chime in on this and see if i'm close.. ;D ::)
"THE BAT"MAN...
Says:
old mod
Re: stall at idle
« Reply #2 on: March 06, 2012, 07:33:28 PM »
my thoughts are...if the crank bearings were that bad it wouldn't start at all, so if it idles without making too much noise i would guess fuel/air. Blocked jet or hole in the diaphragm?
Peters
  • In Glock I Trust
Re: stall at idle
« Reply #3 on: March 06, 2012, 07:43:43 PM »
I'm guessing bad bearing/s would cause extra resistance that would slow the engine at idle to the point it stalls ???
Seems like that would rarely happen. I don't know ???
*2001 ZX-50 beater
thebatman
Re: stall at idle
« Reply #4 on: March 06, 2012, 07:49:36 PM »
When my crank BROKE inhalf... The dam motor was still running. I CUT IT OFF
Another reason to think of carb issue.... IDK
"THE BAT"MAN...
Says:
super9-87
Re: stall at idle
« Reply #5 on: March 06, 2012, 08:43:29 PM »
Well it only  has 5800 miles and only dose it when its hot it will run around 50+ all day its when I come off gas
thebatman
Re: stall at idle
« Reply #6 on: March 06, 2012, 10:23:17 PM »
See.. I'm still thinking carb issue... It's like a jet is wrong on DE acceleration.
With an electrical issue, it would do it when hot but no just when de accelerating.
Maybe Z or word will check in soon and chime in as well
"THE BAT"MAN...
Says:
super9-87
Re: stall at idle
« Reply #7 on: March 06, 2012, 10:56:48 PM »
Idk im New  to scooters  so  I will just mess with it and try to figure  it out any other suggestion   well b taken thanks 4 the help
JustWantToRide
Re: stall at idle
« Reply #8 on: March 06, 2012, 11:41:34 PM »
Take it to a different shop.
2009 Xciting 500Ri
   52mpg so far
