Author Topic: 05 super9 lc  (Read 1477 times)
super9-87
05 super9 lc
« on: March 06, 2012, 06:26:12 PM »
I just picked it up running  a Lil rough well adjusted the carb and now its stalling out at idle after it warns up I took it to a shop and the guy trying to tell me its the main bearing 4 the what the crank shaft what do u think
thebatman
Re: 05 super9 lc
« Reply #1 on: March 06, 2012, 07:04:03 PM »
Posted in the other thread ;)
"THE BAT"MAN...
Says:
Rage
Re: 05 super9 lc
« Reply #2 on: March 06, 2012, 07:18:52 PM »
I would get another opinion. Crank bearings do go.... but they will go noisily. Take the carb off, give a good cleaning. Check plug..... Does it run better when warmed up?
thebatman
Re: 05 super9 lc
« Reply #3 on: March 06, 2012, 07:51:04 PM »
See there... :D JK....
"THE BAT"MAN...
Says:
super9-87
Re: 05 super9 lc
« Reply #4 on: March 06, 2012, 08:46:34 PM »
It runs fine cold its when its hot it dose it when i come off the gas I wants to stall
Re: 05 super9 lc
« Reply #5 on: March 07, 2012, 06:51:34 AM »
..sounds like and idle mix/speed adjustment is all you might need..
..just make sure it's warmed up well before you adjust...
..just thot of this..verify that your water pump is functioning..wouldnt want to over-heat that engine..
« Last Edit: March 07, 2012, 06:53:38 AM by wordslinger »
thebatman
Re: 05 super9 lc
« Reply #6 on: March 08, 2012, 04:58:59 AM »
Yeah, i had gotten real scared like that when my thermostat went out.. She did over heat on me once by the time i got home. Scary stuff... :D
"THE BAT"MAN...
Says:
Re: 05 super9 lc
« Reply #7 on: March 08, 2012, 05:52:08 AM »
Test the auto choke. It may be hanging up, or just plain fried. Loose connection to it?
If the bearings are shot so will be the seal, and that would give the same symptoms. Ask for a second opinion on the bearings.
