Author Topic: sister-sister  (Read 45793 times)
Re: sister-sister
« Reply #165 on: April 09, 2012, 12:08:03 AM »
Maybe air trapped in the top of the Jug? Maybe just one size too lean? After break in they will rev free needing more fuel. If it's mainly the pump tho I would think bearing.
Re: sister-sister
« Reply #166 on: April 09, 2012, 12:11:13 AM »
..josh rebuilt the water pump as well...
..i may go up a jet, just to see if its cooler... but plug looks gooood...
..br8hs plug...
Re: sister-sister
« Reply #167 on: April 09, 2012, 12:15:46 AM »
Even New bearings can be bad. Give him a call for advice.
Re: sister-sister
« Reply #168 on: April 09, 2012, 12:21:48 AM »
..yeah, figured i'd hit him up 2moro...
Areomyst
  • Scootin' America!
Re: sister-sister
« Reply #169 on: April 09, 2012, 02:36:50 AM »
You can drop down to a BR9HS plug.  It is going to be hotter, because the Prima cylinder uses pretty much the same size water jacket as the 50cc cylinder, with a bore that's bigger.  Also the high compression ratio makes it run warmer.  You could swap the cylinder heads (not the whole cylinder, just the head) and you'll probably notice cooler running.
Can't be as bad as the Rotax engine in a Scarabeo 150 that I have in at the moment... got so hot it melted the dipstick, water pump impeller, and even started working on the timing chain guides.  Heh.
~Josh
Re: sister-sister
« Reply #170 on: April 09, 2012, 03:03:44 AM »
..thanx josh, i had thot that the 9 plug might be better...
..it's just that i ride this girl for long stretches..
..and with what you aready said about those primas...being basically oem bored-out, i figured that might be th case..
..warmer weather is making things a bit hotter...probly have to order that ngk9....
Re: sister-sister
« Reply #171 on: April 09, 2012, 03:20:03 AM »
How about a fan? Maybe computer parts, or something from a Honda maybe? Or drilling the shroud for more air flow?
Are you guys talking about adding a wc head?    Sooo many questions... Soooo little time.
thebatman
Re: sister-sister
« Reply #172 on: April 11, 2012, 11:38:34 PM »
Bertha is already W.C.  ;)
that one has a bbk with a modded/bored oem head
OEM pipe....carb
Speaking of which... I found a Naraku bbk cheap but w/o the head... i wondered how that would work out using a regular W.C oem head..(that would get my s9 back up  ;), still no word from Rage on the bbk he was selling........sobbing.. :'()
I know Shaka had the oem head on his zx at one time, of course it's A.C
"THE BAT"MAN...
Says:
Re: sister-sister
« Reply #173 on: April 11, 2012, 11:43:37 PM »
The only issue is using an ac head you have to use a plate to seal the wc jug.
Or I guess you mean an ac S9!
Shaka
Re: sister-sister
« Reply #174 on: April 11, 2012, 11:53:11 PM »
Quote
I did...that was the first Airsal BBK I had on the ZX.  The domed piston with that kit is machined flat around the edge so the piston doesn't hit the oem head at TDC.  It worked great after I made the base spacer to give me the correct durations/squish.
thebatman
Re: sister-sister
« Reply #175 on: April 12, 2012, 12:00:08 AM »
Na, Bertha is L.C..
She had a oem l.c head, bored out to 47mm combustion chamber from the oem 39.
Mine WAS L.C. :D
Poor thing dead beside the z.  :'(  :'(  :'(  :'(
I found a oem l.c head in canada(1/2 $ from new) and that Naraku kit would fix mine. Wouldn't be a malossi kit. :'(  :-\ But she'd run again.  ;)
"THE BAT"MAN...
Says:
thebatman
Re: sister-sister
« Reply #176 on: April 12, 2012, 12:01:09 AM »
Hey Shaka..
Yeah i remember you had good sucsess with that set.
"THE BAT"MAN...
Says:
Re: sister-sister
« Reply #177 on: April 12, 2012, 03:26:35 AM »
I just saw a flash of the dead... Kits. All the dozens of fallen kits. Here's to the Fallen Kits! HIP HIP
Re: sister-sister
« Reply #178 on: April 13, 2012, 12:49:19 AM »
          ..riddle me this, cause it seems i heard someone say it...
..relative excess 2t oil simulates or creates a "lean" fuel mix condition??
Re: sister-sister
« Reply #179 on: April 13, 2012, 12:53:53 AM »
YES. It actually takes up room in the jets that fuel should be going thru. It Dilutes the fuel as it were. Jetting IS dependent on fuel/oil ratio. Change the ratio, and you need to re jet...
