Author Topic: Guages dont work on 07 xciting 500  (Read 870 times)
markmo
« on: March 07, 2012, 07:55:12 PM »
Hello, I am getting my scoot ready for riding and put new battery on it and new airfilter. It started up first time and got to looking at the guages and speed and tack. and fuel guage is not working. The lights an the dash do work. I checked the fueses and all was ok. Can some one help me ? Thanks Markmo
JustWantToRide
Re: Guages dont work on 07 xciting 500
« Reply #1 on: March 07, 2012, 09:36:04 PM »
Two things to try.
1) If it's a dry day then go ride it.  A build up of moisture can cause problems for the gauges.  You can put a fan on it, or go ride it.  After a mile or so it should all reset.  If they aren't working after 5 miles or so then go to step 2.
2) Turn ignition off, disconnect negative battery terminal, turn ignition on, touch negative cable to negative battery terminal.  The gauges should reset to normal.  Turn the ignition off and reconnect the battery.
2009 Xciting 500Ri
   52mpg so far
markmo
« Reply #2 on: March 07, 2012, 10:26:23 PM »
Thanks Just, ALL is working now. Thanks again
bilyum
  • Super 8 150
« Reply #3 on: March 08, 2012, 01:13:32 AM »
You might check fuse holder, the ones on my scoot are cheap and the fuse clamps could be loose!
Later
bilyum
