Author Topic: Regulator/Starter troubles... please help!  (Read 928 times)
stejospot
« on: March 14, 2012, 12:56:23 PM »
Hello all!
So I tried my not-so-crafty hand at some electrical work, and came up short. Pun intended. The general consensus over in the "how to" forum is that either the wrong bulb/fitting or faulty grounding are responsible for shorting my regulator/starter.
But for now, I just need to figure out a way to get the bike up and running again! Right now, the engine doesn't even turn - no sound, no nothing.
If my regulator/starter did indeed get shorted, what is the solution? Do I have to get a new one? Is there a fuse I need switch out somewhere?
I'm a bit desperate at this point and would be extremely grateful for any suggestions. Thank you!
Stejospot
2009 Espresso 150
