Author Topic: agility 50  (Read 966 times)
harleyboy1961
agility 50
« on: March 15, 2012, 04:56:23 PM »
Dose any body have any ideas agility 50cc . cut out while riding, blown a fuse, changed blow again, changed wireing loom. still has no spark at plug but engine turns over,put finger up ht lead lucky no shock , change coil , and cdi unit  no spark at plug , please help
streido
Re: agility 50
« Reply #1 on: March 15, 2012, 06:33:15 PM »
Check the plug end. Maybe take it off the cable and remake the end if it looks bad or worn?
Or check the wiring for breaks or bad connectors?
Chaos is my co-pilot.
Re: agility 50
« Reply #2 on: March 15, 2012, 06:48:48 PM »
I had to replace just the end on mine about a year after I got it I went with a hefy duty one.
try that just replce the end of the plug wire.the stock one can be cheap.
Re: agility 50
« Reply #3 on: March 15, 2012, 11:32:50 PM »
You obviously HAD a short. Use the manual to test the stator. They overheat, and fry the insulator on the windings.
