Did you miss your
activation email
Scooters - 125 to 300
People 150
150 Busted front fender - any easy options?
Topic: 150 Busted front fender - any easy options? (Read 1528 times)
mnewell13
Newbie
March 18, 2012, 06:29:19 PM »
Not in bad shape but was curious if anyone knew where to get a cheap replacement?
this is the front piece covering the front wheel.
Thanks!
You never know do ya!
Close enough to get the idea!
Re: 150 Busted front fender - any easy options?
March 18, 2012, 07:43:12 PM »
Stadium Yamaha for OEM parts. Or try a local body shop. If you remove it they may do it for less than a replacement. Should take a day to fix, and return.
303 whodat
Newbie
May 19, 2012, 05:45:46 PM »
I had a similar problem with a people 50. Removing the fender requires removing the forks, from what I could tell.
If it's 2009-2011, here's the parts picture.
http://kymcopartsonline.com/catalog/search_diagram_detail.php?s_fk_manufacturers_id=21&s_fk_model_year_id=1&s_fk_scooter_model_id=11&osCsid=6d47a4826f6942fbea79cc4e8a0c8d6a&s_parts_diagram_id=220&osCsid=6d47a4826f6942fbea79cc4e8a0c8d6a
According to this it's part # 61100.
$61 as far as I can tell. Removing may be a bit of work though.
2002-2008 may be a bit different, not two tone.
http://kymcopartsonline.com/catalog/search_diagram_detail.php?s_fk_manufacturers_id=21&s_fk_model_year_id=1&s_fk_scooter_model_id=10&osCsid=6d47a4826f6942fbea79cc4e8a0c8d6a&s_parts_diagram_id=187&osCsid=6d47a4826f6942fbea79cc4e8a0c8d6a
_______
When I weighed the options, I decided to buy a $6 bottle of JB Weld at Home Depot and stop the cracks from spreading. I hope this helps.
Reply #3 on:
May 20, 2012, 01:21:13 AM »
You can fill the outside cracks with Crazy Glue as well. It works great as a filler for tiny voids, and you can plane off any excess with a razor.
Reply #4 on:
May 22, 2012, 05:40:12 AM »
GEL type krazy glue holds better and doesnt run.
Back
