Author Topic: ok to use ngk iridium spark plug in p250?  (Read 3245 times)
sedohr
« on: March 21, 2012, 10:53:45 AM »
I've seen posts of people using the newer iridium plug in the p250s. wondering if any issues using in the p250?
just bought my 1st scooter and want to do complete maintenance overhaul.
randy
sw ohio
thanks,
randy
ohio
old geezer
Re: ok to use ngk iridium spark plug in p250?
« Reply #1 on: March 21, 2012, 01:07:56 PM »
I'm running an iridium NGK DPR7EIX-9 gaped to .027 in my 250s with no issues.
juice
« Reply #2 on: March 21, 2012, 01:11:36 PM »
Yes and it will give you superior performance and last much longer , although some folks around here don't think it's worth the extra $4.00 or so . Good luck .
JustWantToRide
« Reply #3 on: March 21, 2012, 02:05:31 PM »
I've never heard of an iridium plug causing problems on any engine, it's always just the question of are they worth it.  I think they are worth the extra cost for any vehicle, and especially in a single cylinder engine.  Well okay - I don't have them in my diesel f250...
2009 Xciting 500Ri
   52mpg so far
gregspeople250
« Reply #4 on: March 21, 2012, 03:50:25 PM »
Iridium, +1!
Honda Elite 80 - SOLD
Yamaha Vino 125 - SOLD
Kymco People 250 - SOLD
Kymco Like 200i - SOLD
Vespa 250 GTS - SOLD
Piaggio BV350 - FUN! - SOLD
Buddy 170i - FUN! - SOLD
Honda Silverwing - SOLD
Yamaha TMAX - OUTSTANDING! - SOLD
Honda SH150 - SOLD
Yamaha SMAX - SOLD
Kymco AK550
sedohr
Re: Re: Re: ok to use ngk iridium spark plug in p250?
« Reply #5 on: March 21, 2012, 07:37:19 PM »
Iridium, +1!
so what makes iridium so great?
sounds radioactive  ;D
thanks,
randy
ohio
juice
« Reply #6 on: March 21, 2012, 07:55:53 PM »
JustWantToRide
« Reply #7 on: March 21, 2012, 10:14:52 PM »
Iridium is the most corrosion resistant and most dense metal.  It's related to Platinum, but even more rare.
2009 Xciting 500Ri
   52mpg so far
sedohr
« Reply #8 on: March 25, 2012, 12:54:16 PM »
so for those of you that've made the switch to the iridium plug - p250 (i have non-S), is it worth the additional costs? can you actually tell a diff in engine behavior?
thanks,
randy
ohio
juice
« Reply #9 on: March 25, 2012, 01:56:46 PM »
Amazon.com ngk standard 5129 $4.12 iridium 7803 $7.40 difference $3.28 . Can you afford to take the chance ? Good luck .
axy
« Reply #10 on: March 25, 2012, 03:50:41 PM »
randy
sw ohio
Any plug with correct specs will work great for you including "Iridium". I have been using regular NGK plugs in my scoots. I change them every 10.000 kms and they look almost as good as new when I change them.
p.s. There is a strong bipartisan movement on the forum related to Iridium plugs and SeaFoam. Beware.  ;D ;D :D
Kymco Agility 125 2008
juice
« Reply #11 on: March 25, 2012, 04:42:22 PM »
p.p.s. There is also a rumor going around that the earth is round , not flat . Beware not to ride over the edge .
Engineer_Boo
« Reply #12 on: March 26, 2012, 04:18:01 PM »
Since going with one, mine seems to start up easier when it's cold...have had NO issues from it...
Iridium Power Plus 1X22B
sedohr
« Reply #13 on: March 26, 2012, 08:41:16 PM »
juice... not an issue affording it but i'm talking about a low hp, non performance scooter here.
got this to battle $4+ gas period.
my etailer has oem's for a buck n change.
since this is my first scooter of any kind, I have zero frame of reference.
just not one to throw dollars at something cause it's new and expensive so must be better.
randy
sw ohio
thanks,
randy
ohio
juice
« Reply #14 on: March 26, 2012, 09:35:43 PM »
Im sure you will be fine with whatever new plug you choose . Good luck .
