Fitted a open cone filter today
![](http://i1193.photobucket.com/albums/aa351/streido/20120324_155927.jpg)
Also upped my jet from 82 to 88. Started it up on the stand and revved it, it died down on revs when i tried to WOT and started kind of pulsing up and down the revs when i tried to hold it on throttle open.
Took some tape and sealed up about half the filter and tried agaim on the stand. It was better but didnt feel quite right. Went for a quick ride and it felt a bit lumpy or boggy when i opened up the throttle past half way. Stopped halfway and took a little tape off to let more air in, that made it worse. Got home and this time i taped up about 2/3 - 3/4 of the open filter and tried it on the stand, that felt pretty good so i went for a ride again. This time it was a lot better and almost felt as good as before i started messing with the stock filter.
So my question is do i just need to go even bigger on the jet? If im on a 88 now and only using 1/4-1/3 of the air filter how large do i need to go do you think so i can ride without tape on the cone? Im thinking at least 100 jet or 110-120 even? Does this sound about right?
Dont want to wreck my engine running lean so any help or advice would be good? I know Wordslinger usually ran 101 or 110 i think on his open filter so im guessing thats my problem, am i just using too small a jet? Checked my plug after my last run again and it looked ok, light tan,on the boggy runs before it was very light tan almost going white.
