Author Topic: Do i need a bigger main jet?  (Read 16868 times)
streido
Re: Do i need a bigger main jet?
« Reply #15 on: March 25, 2012, 12:59:16 AM »
Well there you go, i'll glue it on tomorrow then just in case  :D
Just read on another site where i was looking for jets "Please note after fitting the cone filter that a jet increase of at least 10 - 15 sizes will be necessary to avoid damaging the engine." Says it all, my little 88 jet needs to be at least a 92-97, given how bad it was with no tape im guessing what you said is bang on,  prob get the 95, 98, 100, 102, maybe a 105 or 110 too just in case.
This isnt going to be as quick to set up as i hoped,guess i shouldve planned getting more jets in 1st before i started.  :-[
We'll get there i the end.  :)
Chaos is my co-pilot.
« Reply #16 on: March 25, 2012, 01:03:19 AM »
..you are doing fine, bro...good thing is that you stopped when it appeared to be lean...
..and you pretty much showed yourself by taping over...
..you got this..
..HAPPY TUNING!!!
Shaka
« Reply #17 on: March 25, 2012, 01:33:27 AM »
Also i just read online earlier someone said you need to oil the k&n type filters or they dont work properly? Is that correct? If it is what type of oil do i use?
YES!  It is the oil that actually traps the small particles.  You use specific, "air filter oil."  Otherwise, I know others that use 2T oil in a pinch...never tried that myself though.  The oil also repels water and helps with riding in light rain and wet roads.
PS. Agreed you're running lean. ;)
« Last Edit: March 25, 2012, 01:35:00 AM by Shaka »
« Reply #18 on: March 25, 2012, 01:38:49 AM »
..well damn...
thebatman
« Reply #19 on: March 25, 2012, 01:39:18 AM »
HMMmm, could be why i cant ride in wetness, she will die..... Non oiled filter.
"THE BAT"MAN...
Says:
thebatman
« Reply #20 on: March 25, 2012, 01:39:57 AM »
 ;D :o
Oh Dam, the same quote.... :D
"THE BAT"MAN...
Says:
« Reply #21 on: March 25, 2012, 01:41:48 AM »
...wtf...howd that happen......lmao....
thebatman
« Reply #22 on: March 25, 2012, 01:45:52 AM »
MAaaaaagic.... ;D
"THE BAT"MAN...
Says:
Shaka
« Reply #23 on: March 25, 2012, 01:51:38 AM »
You HAVE to oil the filter!  I clean mine and re-oil regularly...definitely helps, especially in the rain.  Did that today actually! ;D
« Reply #24 on: March 25, 2012, 01:53:03 AM »
..i clean mines regularly...never have oiled tho....
thebatman
« Reply #25 on: March 25, 2012, 02:01:03 AM »
Me either... always been dry as a mo fo....
just thought that was K&N's thing..... ::)
"THE BAT"MAN...
Says:
Shaka
« Reply #26 on: March 25, 2012, 02:06:43 AM »
K&N's are red for a reason....the oil is red.
« Reply #27 on: March 25, 2012, 02:08:07 AM »
...aaaaah...
..never made th' connection.....
thebatman
« Reply #28 on: March 25, 2012, 02:08:34 AM »
+1.......... :-[
"THE BAT"MAN...
Says:
Shaka
« Reply #29 on: March 25, 2012, 02:21:56 AM »
That's OK...Learn something new everyday. ;) ;D
