Did you miss your
activation email
Technical | How To
What tool to remove the variator nut?
Topic: What tool to remove the variator nut? (Read 1331 times)
OregonDad
Full Member
March 26, 2012, 01:08:45 AM »
I am looking for an impact wrench/driver to remove the variator nut on our Agility 50. Our local Sears is closing and all they have left are these
http://www.amazon.com/Craftsman-9-17562-Nextec-12-volt-Right-Angle/dp/B00436U5GG
for 50% off. I prefer the drill style drivers, but will this tool do the job?
Shaka
Re: What tool to remove the variator nut?
March 26, 2012, 01:59:49 AM »
I doubt that will be strong enough to get the nut off. It is only rated at 700 lbs/inch or about 58 lbs/ft.
You never know do ya!
Close enough to get the idea!
March 26, 2012, 02:00:41 AM »
I tried one a neighbor has. It is fine for driving Lag bolts for a deck but not enough UMPH for what you need. The Harbor Freight sells for about 49 bucks with all the do dads.
OregonDad
Full Member
Reply #3 on:
March 26, 2012, 02:46:12 AM »
Thanks, what is the minimum lbs/inch or lbs/ft I should look for?
Reply #4 on:
March 26, 2012, 03:11:56 AM »
Any driver with a 1/2" drive will have enough balls. Too much if you are not carefull. Mark the nut with a Sharpie and when you reinstall it go just a tiny bit past the mark. 1/8th turn at the most.
Shaka
Reply #5 on:
March 26, 2012, 03:26:15 AM »
I have a cordless Harbor Freight one rated at something like 85 lbs/ft. It works just fine except I've run into a few variator nuts that have never been removed before and it can't get 'em. That's why I have a bigger pneumatic one.
OregonDad
Full Member
Reply #6 on:
March 26, 2012, 04:53:46 AM »
Like this one
http://www.harborfreight.com/12-electric-impact-wrench-68099.html
Reply #7 on:
March 26, 2012, 06:19:35 AM »
They have a cordless that sell for that price when it is on sale. You can email them to ask for the next sale date. Other wise it is around 70-80 bucks
Back
