Author Topic: trouble starting need help peoples 250 s  (Read 3242 times)
duke fame
« on: March 26, 2012, 05:55:49 AM »
Hello,
 Just got a used 250 s. I have started this bike twice. Once to drive it home and another a few days ago. The last time I started her I rode it around the block a couple of times and then parked it in the front yard. When I returned I tried to start - no go. After a few cranks the battery begins to fail and then the starter just runs constantly. I pull the starter regulator and find a replacement locally. It is not a Kymco part. the mechanic  at the motorcycle shop says that this part is standard. slap the voltage reg on and it now cranks and begins to start - but kills out after a couple of tries. Maybe I have two rotations through the cycle but no start. I pulled the carb - it looks clean. Electrical? carburetor? I have replaced oil and checked air filter. Its pretty dirty. I'm looking for simple and obvious. this bike was running. Do I check the carb for jet problems? Try something else? BTW it only starts to fire when I give her some gas.
Re: trouble starting need help peoples 250 s
« Reply #1 on: March 26, 2012, 06:56:47 AM »
Get a new battery first thing. When it starts test for charge at the battery. You should see at least 13 volts at 2000 rpm. Also do the shuff you should... Fuel/air filters, spark plug, oil change. It will be fine if you do these. The battery is first.
JustWantToRide
« Reply #2 on: March 26, 2012, 02:02:56 PM »
Ditto
2009 Xciting 500Ri
   52mpg so far
Engineer_Boo
« Reply #3 on: March 26, 2012, 04:45:46 PM »
Ditto on the battery.  And don't spend a lot at the motorcycle/scooter shop, pick up one at WalMart.  (They only last around 2 years for me but I don't put them on a battery tender in the winter.)
duke fame
« Reply #4 on: March 28, 2012, 07:00:42 AM »
well I will order filter and get a new plug. I did fuel and oil - which looked a bit dirty. The battery appears new and is cranking pretty well with a charge. It's posting about 11.2 amps while cranking the starter. Still act like she wants to fire up but dies right away. Then open up the carb and clean? Should I get a new battery? it is cranking pretty well for several minutes before a noticeable drop in power.
BTW the odometer is showing 2000 miles.
Urbestfriend
« Reply #5 on: March 28, 2012, 12:10:07 PM »
Urbestfriend also recommends the new battery.  Same issue with an Agility 50.
Also thought it was the starter solenoid (Like $25.00).   This year new batteries
for both GV and Xciting.  Also charged and they'd start for a day.  They turn over
slower and when you give it a little gas,  they speed up and may or may not start.
I get mine at Interstate.  They can tell you whether its good or not.  Cost there
($80-85).
JustWantToRide
« Reply #6 on: March 28, 2012, 01:21:39 PM »
If you changed the oil but not the filter - then you need to do it again and change both at the same time.
2009 Xciting 500Ri
   52mpg so far
axy
« Reply #7 on: March 28, 2012, 01:54:59 PM »
There is no oil filter. Just strainer, and I never saw anything stuck to it in 50.000 cumulative kms both on Agility and People.
Kymco Agility 125 2008
duke fame
« Reply #8 on: March 29, 2012, 06:13:15 AM »
yes no filter. strainer looked OK. I'll take in battery tomorrow and check. Pretty sure with new battery and plug I should be rocking.
Urbestfriend
« Reply #9 on: March 30, 2012, 09:31:44 PM »
Hoping to hear the solution real soon...................
« Reply #10 on: March 30, 2012, 11:54:46 PM »
I bet Urbestfriend is...
eugenec
« Reply #11 on: April 14, 2012, 01:02:33 AM »
Make sure your kill switch and kid stand switch is in good shape and in the right position.
