Author Topic: Disconnect the ANNOYING "Met-In" Light?  (Read 2996 times)
Engineer_Boo
« on: March 26, 2012, 04:31:57 PM »
My stupid "Met-In" light pops on all the time...even while driving.  Once, it came on while the scooter was in the garage and it drained the battery.
Does anybody know how to wire it so it NEVER comes on?
MaryK
Re: Disconnect the ANNOYING "Met-In" Light?
« Reply #1 on: March 26, 2012, 04:41:13 PM »
It is supposed to come on when the seat is unlatched.  So check and see if your seat is latching securely.
It may need a slight adjustment.
I would guess it is on the same switch that turns the light on in the storage compartment under the seat.
Scoot safely,
New Rider in 2010
2009 GrandVista 250
Engineer_Boo
« Reply #2 on: March 26, 2012, 04:58:58 PM »
Scoot safely,
If I just jiggle the seat, when it's latched, it will come one.  I'll get in there and see if I can figure it out.
juice
« Reply #3 on: March 26, 2012, 06:05:31 PM »
I would think you could either remove the bulb and break the circuit or lift the met in box and seat and disconnect the bulb holder . Good luck .
axy
« Reply #4 on: March 26, 2012, 07:45:30 PM »
Remove the bucket under the seat and disconnect the light.
Kymco Agility 125 2008
JustWantToRide
« Reply #5 on: March 27, 2012, 03:42:49 PM »
The problem is in getting a reliable reading from the switch.  If you don't feel you can adjust the switch or just don't want the light - then I would remove the switch all together.  If you remove the switch and the "Met-In" light comes on - then replace the switch with a little jumper of wire.
2009 Xciting 500Ri
   52mpg so far
