If there is fuel coming out of the float bowl drain, check to see that the drain screw is tight...
But it doesn't need a heavy hand on the screwdriver.
Another posibility is that the needle valve is not shutting off. Then a new needle valve is needed
unless there is an obstruction that keeps the valve open. You can try tapping on the carb with a wooden mallet.
Scoot Safely,
