Author Topic: Changing gear oil  (Read 1063 times)
Zathera
Changing gear oil
« on: April 01, 2012, 11:30:55 PM »
The manual reccomends that I use SAE 90 transmission fluid(same thing is gear oil, right?) But when I go to stores to look for it, they have NOTHING that says just SAE 90, they have 80w90 and stuff. Does the number next to the 90 mean I shouldn't use that oil? Do I really need oil that just says 90? Another question as well. It also says to replace a washer, do I need a special washer to replace it with?
*This is a 2012 model Agility 50 I'm talking about.
Re: Changing gear oil
« Reply #1 on: April 02, 2012, 12:31:44 AM »
80 -90 is ok  and time to time yes you should replace the washer it stops the threads from striping out.
and acts as a seal.
« Reply #2 on: April 02, 2012, 12:51:14 AM »
Your local hardware will have either aluminum or copper CRUSH washers. A few cents each.
REDKYMCO
« Reply #3 on: April 02, 2012, 09:27:45 AM »
This is what i use in both mine and my wife's agility...
http://www.ebay.co.uk/itm/SILKOLENE-BOA-80W-90-HIGH-PERFORMANCE-HYPOID-MOTORCYCLE-GEAR-OIL-API-GL5-/390383084330?pt=UK_Motorcycle_Parts&hash=item5ae4a5232a
Not had to change the washer so far as it has not been crushed by over tighting etc....
IF IT IS NOT BROKE DONT FIX IT:)
Scooter Russ
« Reply #4 on: April 02, 2012, 07:02:00 PM »
80w-90 weight is ok! The way oil works is the lower number in this case 80w oil all the time. But, with the detergents & chemicals in the oil as the oil warms up it changes molecularly to become a 90w weight.
Drive it like you stole it! Lol......
