Author Topic: Agility 50 r16 cdi limit  (Read 4327 times)
franx93
« on: March 24, 2009, 09:29:55 PM »
hello guys, how can i take off the cdi limit? now without all limits (variator, carburator) the scooter go 65km/h...i cut the violet wires...but my friends go 75km/h...is the r16 cdi same as r12? i think no...
by the way, where i have to cut?
thank you!
shermanfunk
  • '09 Agility 50
Re: Agility 50 r16 cdi limit
« Reply #1 on: March 26, 2009, 05:08:49 AM »
this works, i just did it.
http://www.scootertherapy.com/cdiboxcutpage.html
I slowly and carefully made the incision in the same spot as in the pictures with a small hacksaw. the wire is very, very small. I am now able to get up to around 46 or 47 mph!!!
good luck!
franx93
« Reply #2 on: March 26, 2009, 02:09:48 PM »
this is my cdi
the connectors are under...do i have to cut?
another question: where you cut, there is gum, isn't it?
in my cdi there is the gum in that point...do i have to cut under?
« Last Edit: March 26, 2009, 07:44:00 PM by franx93 »
shermanfunk
  • '09 Agility 50
« Reply #3 on: March 27, 2009, 04:00:46 AM »
look at the pictures in the link i put on there. the pictures are blurry, but you will see where to make the cut. Make sure you cut slowly. use  a fine hack saw blade. blow off the plastic residue often so you can see if you've hit the copper yet. you don't have to cut very deep at all. and don't cut past the first copper wire.
franx93
« Reply #4 on: March 27, 2009, 07:50:43 PM »
i did the cut and when i start up from the cut went out flames and smoke...:(
shermanfunk
  • '09 Agility 50
« Reply #5 on: April 03, 2009, 03:22:59 AM »
Yikes! that sucks bad bro! sounds like you must have cut too deep... i'm surprised that didn't happen to mine too....
franx93
« Reply #6 on: April 03, 2009, 04:35:47 PM »
wasn't the cut, was the fuse too high (30A)....so, how can i derestrict r16 cdi?
i tried on another scooter but it didn't work, the method isn't the same as r12!
franx93
« Reply #7 on: April 12, 2009, 02:47:42 PM »
is there anyone?
