Did you miss your
activation email
Scooters - 125 to 300
Grandvista 250
Grandvista noise
Topic: Grandvista noise (Read 5173 times)
packfan
Newbie
Grandvista noise
March 25, 2009, 05:20:00 PM »
I have a 3 year old GV and I ride it all year round, this winter as I was coming home it starting making a noise that sounds metalic. I took it in to the dealer and he believes that I am loosing the crankshaft bearing. I had synthetic oil in it and always change the oil at 5000 mile. Was wondering if anyone eles that has a GV has ever experienced this or heard of it?
jprestonian
2007 Kymco People 250, 2011 Honda PCX
Re: Grandvista noise
March 25, 2009, 06:31:26 PM »
Every 5000 miles?
I think the recommended oil change interval for the GV is every
2000 km
, which is about 1200 miles.
Wanda the Honda
olbull
Full Member
March 28, 2009, 12:15:01 PM »
Yes 1200 miles..There isnt a filter to romove contaminants.... Almost makes using synthetic a waste...Viscosty wont break down in that shorter duration... As the man used to say "pay me now or pay me later"..Im sure there are few old farts on this board that remember that commercial
2007 P250
If your not the lead dog the scenery never changes
drifter
Full Member
Twist n' Go Power!!!
Reply #3 on:
April 11, 2009, 05:05:12 PM »
my gv had 38,000kms (23,750 miles) when i sold it, rode it very hard. had 2 trips 21hrs and 15 hrs straight but never had any problem with the engine. changed oil every 1,000km and gear oil every 2,000km.
"it's more fun to ride a slow bike fast than to ride a fast bike slow!"
Rudolf
Full Member
Born to be wild!!!
Reply #4 on:
July 16, 2012, 09:05:09 AM »
I also hear a clinking noise from the engine only at idle, but when running the engine at higher revs the noise seems to disappear. Here is a clip about it:
Can anyone explain me what makes this noise?
Last Edit: August 11, 2012, 08:43:56 PM by Rudolf
Rudolf
Full Member
Born to be wild!!!
Reply #5 on:
August 12, 2012, 07:31:56 AM »
here is a video with my scooter making a klinking sound even with the variator removed. I believe the freewheel of the starter may have come loose or the bell of the alternator is loose. Correct me if i'm wrong.
Last Edit: August 12, 2012, 07:34:30 AM by Rudolf
Rudolf
Full Member
Born to be wild!!!
Reply #6 on:
August 12, 2012, 07:43:12 AM »
I didn't see any play in the bearings of the crankshaft.
windwheeler
Sr. Member
Reply #7 on:
September 14, 2012, 12:27:16 PM »
It is called "piston slap". Scooter engines have usually more play piston to cylinder, and when it is cold it can make this noise. I bet when you get it really warm/hot it doesn't do it. Mine does it too i idle, cold.
As long as your G/V performs correctly (starts well) and has good power, don't worry to much, unless it aggravates you so much that you want to do a piston/cylinder overhaul.
Rudolf
Full Member
Born to be wild!!!
Reply #8 on:
September 14, 2012, 08:43:05 PM »
The noise is present even when the engine is warm, and it's coming from the right hand side of the engine, i suspect the starter system has some play or something there went loose...
windwheeler
Sr. Member
Reply #9 on:
November 29, 2012, 02:22:08 PM »
Ever found out what the noise was?
Rudolf
Full Member
Born to be wild!!!
Reply #10 on:
November 29, 2012, 02:25:05 PM »
Not yet, i'm waiting for winter to come so i can start the maintenance. As long as the weather permits to ride i'm not gonna start the maintenance because this bike is my only motorized vehicle.
Rudolf
Full Member
Born to be wild!!!
Reply #11 on:
December 27, 2012, 04:28:50 PM »
Quote from: windwheeler on November 29, 2012, 02:22:08 PM
Today on the 27th of December 2012 I've dismantled the whole engine and i've found out that there isn't any problem with the starting system rattling, the problem is elsewhere: I've found out that the cam chain was stretched beyond the cam chain tensioner's limit or maybe the chain is a different size.... The chain has a lot of slack and it wobbled at low rpm and at higher rpm didn't wobble alot. The chain also ground down a little bit from the aluminium casing. There is also some horizontal play in the axle connecting the oil pump with the water pump.
windwheeler
Sr. Member
Reply #12 on:
December 27, 2012, 04:44:47 PM »
How many miles or km are right now on your engine?
Rudolf
Full Member
Born to be wild!!!
Reply #13 on:
December 27, 2012, 04:45:44 PM »
29760 Km, manufactured in 2001. I'm it's second owner, imported from an old man in Italy.
Last Edit: December 27, 2012, 04:48:33 PM by Rudolf
Rudolf
Full Member
Born to be wild!!!
Reply #14 on:
January 04, 2013, 11:31:16 AM »
Here is an image showing where the timing/cam chain was hitting. I have about 0.5mm of free play in every link of the chain.
Last Edit: January 04, 2013, 11:33:37 AM by Rudolf
Back
