Author Topic: Why won't my seat open???  (Read 3153 times)
Hurricane*Sara
« on: April 05, 2012, 09:55:46 PM »
What am I doing wrong?  I push and turn the key to the left....and....nuttin' happens.
I've opened it before and had no problems.
That keyplate thingie is a PITA, BTW.  You can barely read the lettering on it.  I'm still trying to figure out what the two position are at the farthest left.
And I presume there is not a way to manually open the seat, since, well, I guess that would negate the security feature of having a key.  Or is there?
TIA
~Hurricane*Sara
catman2130093
Re: Why won't my seat open???
« Reply #1 on: April 06, 2012, 12:31:20 AM »
Hi Sarah-mine also grew reluctant to pop open,and here is what helps.  Turn the key to the unlock position after the ignition has been on,and put a little lube on the latch.  That teeny bit of lube made all the difference. Good luck! :D
« Reply #2 on: April 06, 2012, 12:33:41 AM »
...i'm not familiar with the gv250, but if there issa cable from keyslot, to seat latch, a good tug on the cable might release the latch...
...i've done that on my a50 before, when i locked my keys in the seat...
peace
catman2130093
« Reply #3 on: April 06, 2012, 12:34:05 AM »
PS-the position all the way to the left will lock the forks,if you have them turned to the farthest left you can steer them..
Hurricane*Sara
« Reply #4 on: April 08, 2012, 05:46:03 AM »
Thanks, everyone.
The seat finally decided to open  ???  So while I had it open, I sprayed it with some dry silicone lube.  Now it seems to be working fine.
Another one of those little mysteries, solved -- sort of.
I appreciate the help!
~Sara
Rudolf
  • Born to be wild!!!
    • Facebook
« Reply #5 on: July 19, 2012, 10:44:19 AM »
Mine had 27033 Km's (about 16797 miles) ridden when I've bought-it.
Peters
  • In Glock I Trust
« Reply #6 on: July 19, 2012, 06:26:20 PM »
Check the screws on the latch under the seat. I had them loosen up to the point one fell out and I barely go the seat open.
*2001 ZX-50 beater
