You may have a bad tank of gas . I would drain and rinse the tank , refill with fresh gas and add 1 oz.per gal seafoam , and replace the spark plug . Good luck .
Thanks to all posts, everyone has been a great help & its great to see the common bond of the US & UK on here :-)
Today's jobs.
1) order new spark plug, done √
2) remove existing plug, clean/replace
3) remove fuel tank, drain/clean/new fuel
4) start engine, warm it up till auto choke has done its job (revs drop), adjust idle speed & mixture screw on carb.
When plug arrives, tomrrow or day after (i hope)
5) replace plug (whats the gap settings, anyone know?)
6) Check idle speed/mixture screw adjust again
7) start up engine & hope i've covered everything to make my scoot run better than ever :-)
P.s on another note, if i get more air flow into the air box by means of extending/making bigger the existing hose, will this be of benefit? I understand i will just have to check/adjust the idle/mixture thats all?
