Hi
My Kymco Top Boy start easily if I kick start it.
When I use the ignition switch, it only start (almost immediately) if I 'wiggle' the key slightly while holding the starter button in. If I turn the key first, leave it and then press the starter button - then the starter turn but the engine don't start. I suspect it don't get a spark in that situation.
I assume it can be one of two things:
1) Faulty ignition coil.
2) Worn out ignition switch
The ignition coil should be easy to replace.
Although I can find a replacement ignition switch (link below), it seems both bolts used to hold it in place on the frame of the Kymco don't have a shape for a spanner. (Rather that the head used to tighten the bolt in the factory sheared of at a certain 'correct' tension.)
So i have two questions:
1) Is my assumptions on the two possible causes correct?
2) Any advice on how to remove the factory fitted ignition switch from the frame?
Thanks, g
http://www.wemoto.com/bikes/Kymco/Top_Boy_50/00-05/picture/Ignition_Switch_Plus_Lock_Set/
