DAM... I sound red-neck as a mo fo there....
W.T.H is up with that?.. Same thing when i was on t.v, sounded country..
Anyway, i guess i should have done a lil more history.
OEM, Several miles on engine, probably 14,500kms. New base/head gasket.
Carb is OEM. She smokes good but will die out like the vid shows. I would not think any lean condition since all is oem.
I have a suspision in mind, for the noise, IDK if you could tell in the vid..
I can still hear it in the vid.
which i do not like the idea worth a sh#t..
I know for sure it's not the W.P, the var side looks good. Bearings tight on both sides.
I will have to rename this thread..
