Author Topic: Looking at buying new Kymco Agility 50. De-restriction procedure Confused Help  (Read 8462 times)
usnapop
Need info for de-restricting a 2012 Agility 50. We own Kymco 2003 ZX-50 that I de-restricted using smooth boss on variator shaft & CDI wiring mod.. Crankshaft broke on that one so we are looking for a new one. I've read info on Agilty board and it seems like the CDI per the discussions is not restricted, but I've seen other information on the Internet where you use hacksaw on CDI. Man I'm confused about that! When I de-restrcited ZX-50 I had to cut some wires and jumper them on CDI. Any info would be greatly appreciated as well as What folks think of Agility 50. Also wondering if de-restricting voids warranty.
whiteknight
  • ..Knight Tweed..
basically its the same procedure, the new Agilitys do have a restriction on the CDI and the Variator. i personally didnt take a hacksaw to the CDI i just brought a new one because it was reletivly inexspensive, as for the Variator you could keep it stock and replace the boss for a smooth one. thats basically all you need to do.
heres what i have done so far.. i have a 2011 Agility:-
Race CDI
Race Variator (cant remember the weights i used)
1500rpm torque spring (came with the variator)
Conti Twist sport tyres
As for the Kymco Agility there a nice scoot, i have pleanty of fun on mine.  They arent too bad on acceleration once you derestrict them and they are great on the corners once you get sum new tyres on them. just keep a check on valve clearence and your oil level.
happy scooting and ride safe
kwflfire
Race CDI
I have a 2012 Agility 50 and found that the boss is smooth, not restricted, but there is a washer under the nut that I took off and it gave me better take off and about 2-3 mph faster.  I am also confused about the CDI, have read that they ARE and AREN'T restricted.
streido
I emailed Kymco UK about this a short while ago, here's what they said,
 " The situation with the Agility 50 cdi has not changed since their introduction, the cdi has a rev limiter fitted on all models leaving the assembly plant."
So there you go, they are restricted in all a50's from the factory.
Chaos is my co-pilot.
Japennell
I'm looking at buying a 2012 Agility 50.  What is the top speed for a restricted showroom scooter?  And does derestricting in itself effect gas mileage as long as driving habits don't change?
whiteknight
  • ..Knight Tweed..
a restricted Ag will do 30 maximum. you need to change the cdi, variator & boss. the mpg wont change. you should still get 100 mpg there or there abouts
Exe
My 2012 Agility with just a smooth boss did 43, so I don't believe the CDI is restricted.
whiteknight
  • ..Knight Tweed..
mine was a 2011 model and the cdi was restricted on that. they would intentionally be damaging there engines if they put unrestricted cdi's in but restricted the variator, the engine would be revvin its nuts off but only doing 30 mph *Engine goes POP*
