Author Topic: My agility is making noises (video included)  (Read 7027 times)
Re: My agility is making noises (video included)
« Reply #15 on: April 15, 2012, 04:35:48 PM »
just get a good can of carb cleaner. spray it all down and you should  be good to go.
just keep a good eye on the little pieces spray the jets good maybe poke with a fine needle.
make sure jets are put back in tight. try recapeing your plug too.
« Reply #16 on: April 15, 2012, 06:31:33 PM »
...ive adjusted my valves on agilitys for over 90,000kms at .04mm....
..then again, i could be wrong...
« Last Edit: April 15, 2012, 06:37:42 PM by wordslinger »
« Reply #17 on: April 15, 2012, 07:12:48 PM »
looks like we have a debate on are valves going here.  I have done mine both to 04 but my opinion is 02 and 04 works the best for me. so I guess its up to the owner of his own scoot to make his decision on this.
baddi
« Reply #18 on: April 15, 2012, 08:10:53 PM »
Spray? :S
I'm sorry for being unknowing, but is it as simple as to take it apart and spray it with something? :D
« Reply #19 on: April 15, 2012, 08:26:20 PM »
just becarefull and dont lose anything. do it over something that well catch any little things that might fall out it needs to go back the same way you found it. the jets have to go back tight. ounce you take the bottom bowl off open slowly and dont turn upside down there is a small peice under the main jet that might fall out it might stay in place. you may not have to worry to much about the other side but you can if you want. just put everything back the way you see it. no if or butts.
« Reply #20 on: April 15, 2012, 08:27:31 PM »
o ha please redo your valves at leased do the 04 on both.
baddi
« Reply #21 on: April 15, 2012, 09:57:46 PM »
But what if... "I like big butts and i cannot lie..." xD lol.
« Reply #22 on: April 15, 2012, 10:08:57 PM »
...lmfao!!!.......
« Reply #23 on: April 15, 2012, 10:39:38 PM »
I like theam round and juicey...........
whiteknight
  • ..Knight Tweed..
« Reply #24 on: April 15, 2012, 10:56:06 PM »
So your girlfriend rolls a Honda, playin' workout tapes by Fonda
 But Fonda ain't got a motor in the back of her Honda
baddi
« Reply #25 on: April 15, 2012, 10:56:40 PM »
Here is one for you:
O
Round and juicey. :)
« Reply #26 on: April 15, 2012, 10:58:15 PM »
On my GY6 I found running the scoot for a few miles to warm it up, and adjusting the valves hot makes it much easier. I just loosen the lok nuts, and turn the adjuster by hand till it touches the valve stem. That gives Zero play hot, and .003 cold. I've done it one time, and have NOT had to re adjust yet. If you do it carefully you can slide the rocker arm back, and forth but no up or down movement. Just like old school solid lifter cams in hot rods. The engine is perfectly quite, and much peppier. Give it a try!
« Reply #27 on: April 15, 2012, 11:01:02 PM »
   +1 z
..done it, and it works...and you get same results adjusting cold...i just dont preach it...lol..
« Last Edit: April 15, 2012, 11:23:48 PM by wordslinger »
