Did you miss your
activation email
Scooters - 50cc
jets
Topic: jets (Read 671 times)
jets
April 13, 2012, 01:48:25 PM »
I need to replace my main jet back to the 82 .But right now I have a gy6 19mm carb on it.and by looking at the jets there is a big dif in size the 78 jet only has 3 holes on each side of it and the 82 kymco jet has 4 . the 82 fits in the carb but it sits up a lot higher in the carb is that going to be ok to try this 82 in this carb.
You never know do ya!
Close enough to get the idea!
Re: jets
April 14, 2012, 04:31:42 AM »
The atomizer holes wont matter. They are specific to the jet. The height will matter tho. If it sits too high it will drain the bowl level, and starve. Try Lok Tight to secure it lower in the port. That should work.
Back
