You should be fine just do not go to much over 30mph to keep the revs down once you get the smooth boss done your drive belt can travel further up the variator so that will then help keep the revs down...
this is with only cdi done and drive boss done! any ideas how many mph they main jet 82 will add?
..i just saw a smooth 39mm boss the other day, onna 2012 "peace sport" 50.....smooth...no step, oem.....also has a shorter belt, and restricted driven pulleys and non-adjustable carb....
