Author Topic: starter  (Read 5586 times)
Re: starter
« Reply #15 on: April 18, 2012, 09:06:08 PM »
its all good mine is broke any ways I tryed to fix today and put it back in and it just keeped geting stuck.
time for new. the teeth on mine are bad also.
why cant we all just get along ............... rember that song why cant we be friends.
Re: starter
« Reply #16 on: April 18, 2012, 11:59:25 PM »
Re: starter
« Reply #17 on: April 19, 2012, 01:03:29 AM »
OMG..................to funny thats a good one...............................maybe its time to take the wife out for a walk.
Re: starter
« Reply #18 on: April 19, 2012, 02:17:56 AM »
 ;D
whiteknight
  • ..Knight Tweed..
Re: starter
« Reply #19 on: April 19, 2012, 09:55:23 AM »
hey blue did you know summit was up with the starter when you goto start it and all you get is a clicking sound? im having probs with mine starting at the mo, if i goto use the electric start all i hear is a *click click* noise when i press the button.
Re: starter
« Reply #20 on: April 19, 2012, 11:36:39 AM »
ya Mine does the same thing .But with the bendix out the starter motor works. with the bendix in it wont work. If I leav it in it just shoots out and gets stuck then the motor just clicks.try takeing yours out and use just the kick start.
streido
Re: starter
« Reply #21 on: April 19, 2012, 08:23:53 PM »
WK is your battery ok? I had a bad regulator last year and my battery wouldnt charge off the motor so o jad to use a charger every wk or so to boost it up. When it was almost out of charge i got the click click noise but it wouldnt come close to kicking the motor over.
Chaos is my co-pilot.
streido
Re: starter
« Reply #22 on: April 19, 2012, 08:25:33 PM »
..... cont. If you can run a set of jumper leads off a car to your battery and try turn it over with the elec start it will tell you if its your battery at fault or not.
Re: starter
« Reply #23 on: April 19, 2012, 08:30:55 PM »
no no no dont try a car battery I have seen scoots wireing melt down right in front of me by trying that.
but you can use a deep cycle battery from a boat they dont put out so big of a charge .
streido
Re: starter
« Reply #24 on: April 19, 2012, 08:36:01 PM »
No blue, i dont mean to run a car battery instead of your scoot battery, just use it for a jump start. I did mine at least 3-4 times and it was ok? Still use the same scoot battery today, 1 yr later.
Re: starter
« Reply #25 on: April 19, 2012, 11:01:29 PM »
...blue...make sure you still have this steel bushing in your cvt cover as well....
whiteknight
  • ..Knight Tweed..
Re: starter
« Reply #26 on: April 19, 2012, 11:15:48 PM »
ah right okie dokie. i shall do that. i know it cant be the battery though because i had it changed not so long ago because my old on ewas the original that had done 12,500 miles.
Re: starter
« Reply #27 on: April 19, 2012, 11:43:37 PM »
You most likely have a bad starter relay. You can replace it w/ a Bosch or Cole Hersey from the autoparts. You will have to remove the terminals from your plug, and stick them on the new relay.http://www.google.com/products/catalog?client=opera&rls=en&q=bosch+30a+relay&oe=utf-8&channel=suggest&um=1&ie=UTF-8&tbm=shop&cid=5981072858508301476&sa=X&ei=C6OQT76BBqiF6QGX9tSzBA&ved=0CIgBEPMCMAE
Re: starter
« Reply #28 on: April 20, 2012, 12:55:23 AM »
all parts are there for some reason when I push the start button the bendix shoots out and gets stuck and then the elc. start just clicks after that. the elc works but the bendix sticks So it must be to bad to try to use Im good with the kick start for now. as long as the scoot dont shut down on me when rideing because then I have to rekick it on the side of the road . not good.
Re: starter
« Reply #29 on: April 20, 2012, 01:36:17 AM »
..i have a cpl good bendi....
...pm me your address, i'll mail you one...
                      ;D
