Author Topic: thermostat for water cooled super 9  (Read 4600 times)
justmalc
« on: April 19, 2012, 01:07:50 PM »
Hi does anyone know where I can get a Thermostat for the super 9 lc.? Is this engine used in any other bike?
Many thanks. Malc.
thebatman
Re: thermostat for water cooled super 9
« Reply #1 on: April 19, 2012, 10:02:11 PM »
19300
19300-KE1-0030-M1
 THERMO STAT ASSY
$42.45
http://www.stadiumyamaha.com/pages/OemParts?aribrand=KYM#/Kymco_USA/Super_9_Three_Tone_2004/Water_Pump/2K01200005/01200003
Here you go.... pretty good ship time from these guys. I normally get my oem parts here as well..
Hope this helps.  ;)
Keep us posted...
WELCOME TO THE FORUM...... ;D
"THE BAT"MAN...
Says:
« Reply #2 on: April 20, 2012, 02:37:32 AM »
..holy hot water batman!!!
...i need me one of them!...
justmalc
« Reply #3 on: April 20, 2012, 09:42:44 AM »
Many thanks for the quick response chaps.
Any Cheaper supplies?  ;D
Regards (skinflint Malc).
« Reply #4 on: April 21, 2012, 01:14:34 AM »
Run without it.
« Reply #5 on: April 21, 2012, 11:26:16 AM »
Run without it.
..doin it!
« Reply #6 on: April 21, 2012, 08:12:12 PM »
In some cases there is no reason not too. Sometimes tho the water passes thru the radiator soo quickly it does not have a chance to loose enough heat. Is this the scoot you have the temp. issue with Slinger? That could be the cause... Just thinking.
Some will run much cooler w/out a t-stat due to better flow so trial, and error.
« Reply #7 on: April 21, 2012, 08:36:51 PM »
..i took the thermostat out troubleshooting the problem....
..helped a little, but still hot after a few miles of running...
..josh said it's going to run hotter, but it melts my cvt fans....
..wasn't an issue in the winter..
« Reply #8 on: April 21, 2012, 11:01:27 PM »
Perhaps boiling out the radiator? Could be some blockage. Or maybe since it's a bigger jug with LESS water area a bigger Rad? or a second small rad under the belly
« Reply #9 on: April 22, 2012, 01:24:27 AM »
..y'know...that pump was sh**, before j rebuilt it....
..anybody know a good way to verify coolant flow??
« Reply #10 on: April 22, 2012, 02:10:24 AM »
You have to know the base flow rate to compare. You also have static pressure testing but again you need a base to compare.
Run the inlet side of the pump into a 5 gallon pail, and the outlet into the same pail. At cruise rpm take the outlet hose , and put it in a quart bottle. Time it till full. That will give the gph of the pump. For pressure it is the same as a home inspector uses. A pressure gauge mounted to the outlet side rated at cruise rpm.
 Perhaps someone will compare to give you the base line #'s.
I mentioned using a Quart bottle. That is to keep from melting the jug by filling a gallon.
« Reply #11 on: April 22, 2012, 02:14:33 AM »
I said pump in the post but meant the Radiator. The bucket replaces the Rad.
 On marine engines I look for a 1" hose to shoot 1' above the hose at cruise rpm. Like a fountain in the park.
« Reply #12 on: April 22, 2012, 02:33:53 AM »
..i got that...when i get time, i wanna compare the two s9s flow rates....
« Reply #13 on: April 22, 2012, 02:37:52 AM »
I forgot you have twins...
« Reply #14 on: April 22, 2012, 03:12:48 AM »
...well, fraternal at best...
..they two different bitches!!!
                    :o
