Author Topic: Rear brake Startup Problem  (Read 619 times)
schmarkeep
« on: April 20, 2012, 10:28:50 AM »
When I try to start my GrandVista 250, I usually hold in the left brake and press the ignition.
Now, when I try to start it up, it doesn't start.  I have to hold in the right brake and start it.  How can I fix the left brake lever/start?
Re: Rear brake Startup Problem
« Reply #1 on: April 21, 2012, 02:00:14 AM »
The problem can be anywhere in the wiring harness. You will need a multi meter with a continuity tester for the trouble shooting, and a hammer to take the body off. The hardest part of chasing wire problems is dealing with the body.
