Author Topic: Who cut my cdi?  (Read 7962 times)
Matty
Who cut my cdi?
« on: April 20, 2012, 07:07:59 PM »
Hi folks
Can anyone tell me if the below is a CDI that has been cut, or not?
Also is it possible that an incorrectly cut CDI can result in a slight loss of power
Re: Who cut my cdi?
« Reply #1 on: April 20, 2012, 07:17:57 PM »
..looks like its been cut and epoxied over. .
..but no, cutting cdi incorrectly is virtually impossible, and will not result in rpm loss...
peace
Re: Who cut my cdi?
« Reply #2 on: April 20, 2012, 08:49:05 PM »
that looks toasted.what happen
whiteknight
  • ..Knight Tweed..
Re: Who cut my cdi?
« Reply #3 on: April 20, 2012, 10:10:47 PM »
are you sure thats not yours blue? with your track record it could be  ;D
Re: Who cut my cdi?
« Reply #4 on: April 20, 2012, 10:34:23 PM »
HAY not nice.......LOL    Im on a good track now. my scoot is doing relly good as long as I keep my hands off it. my last mod was to turn it in to a low rider. smaller shock.
Matty
Re: Who cut my cdi?
« Reply #5 on: April 21, 2012, 08:58:13 AM »
thanks guys. blue it works fine, i'm just trying to work out if it has been cut or not - can anyone answer for sure?
I still have very average performance on my scoot so I'm just trying to identify the cause. But from what wordslinger has said (thanks wordslinger), it's unlikely to be my cdi that is the problem.
Back to randomly replacing everything I guess....
Re: Who cut my cdi?
« Reply #6 on: April 21, 2012, 09:12:57 AM »
Try replacing the CDI and see the difference in performance.
Re: Who cut my cdi?
« Reply #7 on: April 21, 2012, 11:24:10 AM »
..do you have a restricted drive boss?..if so, that should be the first thing you randomly swap...lol..
Re: Who cut my cdi?
« Reply #8 on: April 21, 2012, 11:31:22 AM »
Back to your question the cdi dont look like its been cut.if so there would be a notch cut out on the end wear it looks burned.
whiteknight
  • ..Knight Tweed..
Re: Who cut my cdi?
« Reply #9 on: April 21, 2012, 03:08:51 PM »
from the look of the pic it has had the ordinary hacksaw treatment, i can see were the cut is from the pic. i could even opint out where it has been cut.....if you wanted
Re: Who cut my cdi?
« Reply #10 on: April 21, 2012, 04:00:33 PM »
...it is visible, and i wonder if the cut is deep enough...
Matty
Re: Who cut my cdi?
« Reply #11 on: April 21, 2012, 04:03:06 PM »
thanks whitenight.
yes i think you're right there does seem to be a cut line amongst the epoxy. will go check on the thing itself. I do get 40mph out of it (on the speedo at least) so I think the cut has been done correctly. I just have poor acceleration.
i have a derestricted drive boss.
valve clearance is normal.
I think compression might be the problem.  i have a compression tester but annoyingly it wont fit in the hole in the agility due to constrained space.
incidentally idle mixture screw seems to have no effect however it's turned and the thing loves to idle low and cut out. Idon't know if that is symptomatic of a general fuel line problem which might be causing my generally poor power (in particular acceleration)
Re: Who cut my cdi?
« Reply #12 on: April 21, 2012, 04:04:29 PM »
Re: Who cut my cdi?
« Reply #13 on: April 22, 2012, 01:31:47 AM »
...valve clearance is .04mm...just throwing that out there...
..you should be gettin a bit better than 40, with cdi and boss...
Re: Who cut my cdi?
« Reply #14 on: April 22, 2012, 02:36:57 AM »
First it was cut not burned. The epoxy is peaky from application.
Second cutting the cdi does nothing for performance. I will only allow the engine to rev to it's peak.
Third it sounds like your idle jet or mix port is clogged. Start by disassembling the carb, and cleaning everything.
Lastly the cdi was cut/epoxied to protect it by Yolanda Greene. She lives in New Jersey.
This guy is on Oxy's or Something but it covers the basics
