...the rubber "PCV" effect tube, attached to the valve cover does indeed go to the oem airbox.....just opposite of where it enters, there is a clear tube, that routes beneath the aibox toward the rear....the venturi effect does "draw" oil vapor from the valve cover, and the vapor condenses in this space between the two tubes.....that oil should be drained from the clear tubing periodically...
...there shouldn be any oil from the carb intake, but theres gasoline vapor that get's dopplered out and condenses, with some of the oil vapor from tubing...
...what's your cvt setup, whiteknight?
I think it might be because the tube from the valve cover leads it to the air filter, where it because of venturi effect is sucked up into the air flow to lubricate the engine from the ignition side of the piston. But just a guess.
...how old is your belt?..i've been running with that tube tucked for 3 years..it's what you do, when runnin k&n filter...don't sweat it...
...think hes sayin kmsDE-DE-DEEE...Guess your right on that one.... WE measure that over here... 14,000Kms come to like 8700miles
im not sure but i think my odometer is reading miles. so i think i have done 14,000 miles. i would be checking everything but it seems that i work, work, work then speand a hell of a lot of time sleeping.
