Author Topic: driving pully lock wrench  (Read 4140 times)
boo
« on: April 23, 2012, 01:39:30 PM »
I know the GT is new and most have not put on enough miles to get into belt and roller weight replacement but, is a variator wrench available for the GT and Downtown?.
I`m speaking of the gismo that holds the variator still so one can use a torque wrench to properly torque the variator nut, "driving pully lock wrench".
Some use a screw driver placed through the fins on the variator but, quite often end up breaking a fin.
I have a low power 12v electric torque wrench but, when torquing, I would prefer to torque by hand.
« Last Edit: May 03, 2012, 09:47:56 PM by boo »
300GTI black
Pro 2A - member GOA & NRA
iker
  • , 2007 kymco people s125
Re: variator nut hold wrench ?
« Reply #1 on: April 24, 2012, 03:09:36 AM »
boo, i have used a impact wrench for years on lots of variator and clutch nuts.
use same power setting you use to remove nuts when putting nuts back on. that sounds silly but it works.
2007 kymco people s125 aka - lit red
2011 vespa gts 300 super aka - tin man
« Reply #2 on: April 24, 2012, 03:32:15 AM »
boo
anyone ? nt
« Reply #3 on: April 28, 2012, 11:46:38 PM »
Looking for a job specific commercial tool.
300GTI black
racewalker
« Reply #4 on: April 29, 2012, 01:27:04 AM »
I made mine and use the same one for both my people S 125 and my DT300I. JUst put sliders in last week. Haven't been able to tell how they are working as I have had 40-60 K winds all week. Really blows the gas milage away.
08 People S 125
11 Downtown 300i
Hoolander2
« Reply #5 on: April 29, 2012, 06:00:16 AM »
http://www.motorcycle-superstore.com/2/9/205/4896/ITEM/Motion-Pro-Clutch-Holding-Tool.aspx This should work.  I got one and had to very slightly grind the pegs smaller.  Now it works great.  Also you might have to file out any slag aluminum in the two variator holes if they didn't do a good job of it at the factory but that's a minor job with a rat tail file taking 5 min.
Assuming the 300's variator has the same holes as the rest.
boo
« Reply #6 on: May 03, 2012, 05:07:43 PM »
I personally would not be comfortable using an impact wrench to put the nut back on.  You can damage the shaft.   The impact wrench will get the nut off ok, but torqueing down the nut is easy, with a wheel on the ground, to proper spec.  I am sure the impact wrench WILL get the nut back on, but it is not ideal.
I have seen too many untrained kids at oil change places and tire shops do serious damage to different machines by putting nuts or bolts on with an impact wrench.  It is far too easy to over torque.
I know a lot of scooter riders use low powered 12v impact wrenches to tighten the variator nut. Most of the time without problems.
I prefer to gently torque it on with a torque wrench.
If someone has a shop manual for the GT or Downtown, it usually gives a picture and part number for the driving pully lock wrench.
The part number and price is what I was looking for.
I like to use the right tool for the job.
Stripping the threads on the variator shaft would be a pisser.
« Last Edit: May 03, 2012, 09:46:24 PM by boo »
300GTI black
kayakbuilder
Re: driving pully lock wrench
« Reply #7 on: May 26, 2013, 04:43:17 AM »
Universal Holder E017
'13 Downtown 300 White
'08 Yamaha Zuma Raven 70cc BBK, LV ZX Exhaust, CF Reeds, Sport Windscreen, SOLD
'99 Yamaha Zuma II 70cc BBK
James 1:27
« Reply #8 on: May 26, 2013, 05:55:20 AM »
   I found a cam holding tool at princes auto canada.  $14. 95     I had to grind the pegs down to fit the holes in the variator,.  or you can make your own, one piece 14 inches and one piece 5 inches two bolts that fit in the variator and one to hold the two pieces together to make a Y
MotoRandy123
  • Lets Ride!
« Reply #9 on: May 26, 2013, 09:58:09 AM »
From the manual;
I just use a belt wrench, does the clutch too!
boo
« Reply #10 on: May 26, 2013, 03:03:26 PM »
From the manual;
Motorandy123, It has been a while since I posted this.
I made myself a variator and clutch holding tool.
1/4" aluminum stock
Will give it a try at 8,000-10,000
We have two scooters in the family. Hope it will work on both.
« Last Edit: May 26, 2013, 03:12:17 PM by boo »
300GTI black
