Author Topic: Did Kymco make a 4t ZX50?  (Read 1299 times)
Japennell
« on: April 25, 2012, 03:11:51 PM »
I'm asking because a CL add has one listed as a 4T.
Re: Did Kymco make a 4t ZX50?
« Reply #1 on: April 25, 2012, 11:38:14 PM »
NONE. This may be a conversion or typo. 2t's don't last too long so it may be a gy6 engine in a ZX. It's worth a call out of curiosity. Can you post a link?
Japennell
« Reply #2 on: April 26, 2012, 10:44:39 AM »
Sure.  http://newhaven.craigslist.org/mcy/2900111851.html
However, it was his text that said it was a 4t.  Must be a typo.  Thank you for confirming.
« Reply #3 on: April 27, 2012, 01:19:08 AM »
2006 was the last year they were made so it is still needing everything rubber replaced, as well as the usual tune up stuff. Low miles are good but years are bad. If you like it check for cracks in the rubber (hoses/lines/controls/tires) This will add to your cost.
« Reply #4 on: April 27, 2012, 01:21:03 AM »
Ps... Mine is an '05, and I got it mint w/11,000 on the clock for three hundred. Shop more. Kelly blue book is only 987.00 Retail, and 547.00 trade in
Japennell
« Reply #5 on: April 29, 2012, 11:21:10 PM »
I picked up an 05 with 1300 miles on it.  It needs a battery and has not been tuned up in a few years.  Even so, it ran real nice.
He also had new front plastics and underside even though they are not needed.
« Reply #6 on: April 30, 2012, 12:06:54 AM »
Very nice looking scoot. I forgot what mine looked like new. I see the Tech. pipe. What other mods are there? What is the top speed as is?
Japennell
« Reply #7 on: April 30, 2012, 11:29:04 AM »
Thanks.  According to the seller, the pipe was the only mod.  He says it does 47 mph.  I easily hit 40 yesterday without going full throttle.
I love it!!!  What a difference from my Spree.
The battery was dead so I charged it last night.  However, I am still unable to use the electric start.  Not a big deal and I will make sure I am trying to start it correctly before I assume the worse.
I am also going to change the plug as he said he only put gas and oil in it since he owned it.
The throttle seems to stick from a dead stop and then it wants to jump.  Could that be related to a old plug or is it likely the actual cable/throttle assembly itself?
There also seems to be a slight rattling sound as well.  He says it was the kick stand.
If the muffler is changed, are there other mods that should be done along with it for mechanical reasons?  I want to make sure that what he did was complete.
« Reply #8 on: April 30, 2012, 07:34:46 PM »
There is a long list of to do's. Cable is first. Disconnect it from the carb, and the oil pump. It should move smooth.
