Author Topic: Dimensions for smooth boss?  (Read 3000 times)
callumP
« on: April 26, 2012, 07:21:59 PM »
Could anyone make me up a drawing for a smooth boss and send it me? I have access to a lathe and ill make the part just need dimensions,
Thanks!
streido
Re: Dimensions for smooth boss?
« Reply #1 on: April 26, 2012, 10:36:52 PM »
Take out you restricted boss and lathe it down level, the length is the sameso just lathe off the raised part.  Thats how i did mine and its better fitting than a smooth boss i got online.
Chaos is my co-pilot.
streido
« Reply #2 on: April 26, 2012, 10:40:24 PM »
My lathed boss and the one i got online, The online one is the really worn one, and it only did less than half the miles of the stock boss.
callumP
« Reply #3 on: April 27, 2012, 06:23:21 AM »
i still need the original because i am swaping the parts back over for service to keep my warrenty, ill take it out and measure it up though!
whiteknight
  • ..Knight Tweed..
« Reply #4 on: April 29, 2012, 01:12:38 PM »
i've had a look in the service manual and it says the service minimum 19.97mm so i would hazard a guess at it being 20-21mm but please dont take my word for it. i couldnt find the original OD size all it stated was the service minimum.
« Reply #5 on: April 29, 2012, 01:17:09 PM »
theres that warrenty word again gooooooooooooooooooood luck.
streido
« Reply #6 on: April 29, 2012, 01:52:42 PM »
Wordslinger posted pics of his boss on a micrometer so you can see the sizes you need here http://www.kymcoforum.com/index.php?topic=6303.15
callumP
« Reply #7 on: April 29, 2012, 02:23:06 PM »
thanks for the link, and what did you mean by warrenty, are you saying kymcos warrenty is sh**?
baddi
« Reply #8 on: April 29, 2012, 02:46:29 PM »
Warrenty is warrenty, and many of the essential bolts have a blue piece of paint, so the mechanic can see, if you have had it off. If you have, then you've got no warrenty, as the warrenty only persist, if only a certified mechanic have serviced the scooter. :)
callumP
« Reply #9 on: April 29, 2012, 04:20:44 PM »
but the variator should have been looked at so he mush have removed the bolds before, in my service manual it says check belt and rollers and this section is ticked so he must have looked so the paint will have gone?
baddi
« Reply #10 on: April 29, 2012, 04:27:56 PM »
Then perhaps no problem then, when he himself have broken the seal, without painting a new line. ;)
whiteknight
  • ..Knight Tweed..
« Reply #11 on: April 30, 2012, 12:23:42 AM »
damn im getting f*cking good  ;D  i guessed 20/21mm and the stock OD is 20 mm. im quite happy about that. sorry gettin carried away.
« Reply #12 on: April 30, 2012, 12:55:24 AM »
...should be 38mm...thisn is a bit short, which is goood...for a lil more top..
« Reply #13 on: April 30, 2012, 12:56:01 AM »
...20mm...
« Reply #14 on: April 30, 2012, 12:56:35 AM »
...14mm...
