Author Topic: Kymco People 150 problem with scooter when starting from a dead stop.  (Read 3194 times)
KevinR
I have a 2006 Kymco people 150 and am having some problem with starting from a dead stop.Here is what happens when i give it the gas it starts out just fine but when it goes maybe 2-3 ft then it feels like the clluth really grabs and makes the scooter jerk forward alittle and then everthing is just fine.I opened the cover and cleaned the rollers ,the roller look like they are ivory in color but no writing anywhere on them.I really don't know where to go from here.If i am needing new rollers ,Variator,clutch springs and contra spring could you please tell me what to buy and maybe where to order them.I just want the scooter to run like stock i don't need it to be faster or quicker off the line just smooth. Thank You Kevin Ratekin Topeka ks.
Calothrix
Re: Kymco People 150 problem with scooter when starting from a dead stop.
« Reply #1 on: April 28, 2012, 02:40:01 AM »
Maybe you need to deglaze your clutch shoes.  Try "sanding" them with some emory paper to remove the glaze and also clean the inside of the clutch bell with denatured alcohol or brake cleaner.  It worked for me when I had the same problem on my '05.  Good luck.
« Reply #2 on: April 28, 2012, 02:51:13 AM »
...yup...and how many kms you have on ur scoot??...
« Reply #3 on: April 28, 2012, 03:07:00 AM »
happened to me. I just "twist and go". It went away after about a week.
KevinR
« Reply #4 on: April 28, 2012, 03:18:09 AM »
My scooter has 5k kms on it and i think i will try the sanding that you guys said may work and i'll let you know.Thanks for the info everyone. Kevin
« Reply #5 on: April 28, 2012, 03:25:58 AM »
..after 5k, you cvt needs a thorough cleaning...
..i have pics of a 7500km 50cc inspection here..
"http://www.kymcoforum.com/index.php?topic=6303.15"
..so, you can imagine how much harder your tranny is working...
KevinR
I did clean CVT and sanded the clutch pads like you guys said and now it runs just fine thanks for the info guys.  Kevin
