Author Topic: NGK (7544) CR7HIX Iridium IX Spark Plug gap?  (Read 12114 times)
Re: NGK (7544) CR7HIX Iridium IX Spark Plug gap?
« Reply #15 on: April 28, 2012, 09:19:07 PM »
Dont always trust in what you read.
« Reply #16 on: April 29, 2012, 03:35:05 AM »
According to that article I should also get a high energy ignition coil/wire/plug cap to improve starting, acceleration, and fuel mileage.
That is the very first thing you should do. I see it as a "given". You have to have at least 35,000 volts to get complete combustion. Most if not all OEM 50cc coils are 6,000v. Get one of the orange "performance" coils on ebay, or partsforscooters. You will get better performance /mileage. I am setting up an MSD battery driven CDI, and an Accel coil made for a 2012 jeep. That will be a stable 60,000 volts from start up to 16,000 rpm. Fire is the trigger.
baddi
« Reply #17 on: April 29, 2012, 01:05:25 PM »
As far as i was told, the standart kymco coil was 16000 volts.
Naraku is one of the very experienced and trusted producents of tuning parts for 4-stroke GY6 engines, and their orange performance coil (i wonder why all of them are orange, no matter who makes them) are 31000 volts, so i would suspect, that no higher than that would be necersary. :)
« Reply #18 on: April 29, 2012, 07:52:33 PM »
"As far as i was told, the standart kymco coil was 16000 volts."
 Forgot the one (1) 16,000v. Still half the power, and MUCH weaker spark under compression. You want the spark to jump at LEAST 1/4" with the plug outside the engine.
baddi
« Reply #19 on: April 29, 2012, 08:13:03 PM »
How much is that?
A quarter inch? :)
« Reply #20 on: April 29, 2012, 08:18:22 PM »
One quarter inch. http://www.toolfetch.com/Category/Automotive/Spark_Testers/THE404.htm  This is the tester I use to trouble shoot. If I cannot get a 1/4" gap to jump I KNOW it will be an Ign related running problem.
baddi
« Reply #21 on: April 29, 2012, 08:44:07 PM »
I ment more like, what is it in centimeters, but i found out now. :D
Its only a little more than 0,6, so any coil should be able to do that. :)
« Reply #22 on: April 29, 2012, 09:30:50 PM »
Any Good coil. Compression increases the air resistance inside the Cyl. I don't know the formula but I do know you have to jump 1/4" to get spark under compression. Even erratic spark at 1/4" will not fire in the cylinder under compression. At 60,000 volts you don't even need an electrode. It will jump to ground.  http://compare.ebay.com/like/390407578892?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar  That is the OEM plug for a 60,000 volt marine 2t engine (out board)
baddi
« Reply #23 on: April 29, 2012, 09:48:51 PM »
Awesome! I didn't know that ;)
« Reply #24 on: April 30, 2012, 12:52:52 AM »
..wowww....
      :o
« Reply #25 on: April 30, 2012, 01:27:43 AM »
Now...do you need iridium?
juice
« Reply #26 on: April 30, 2012, 01:55:38 AM »
Nobody NEEDS iridium . It's more a question of do you want to pay the extra couple of dollars for the improved performance , easier starting , and longevity .
« Reply #27 on: April 30, 2012, 01:59:53 AM »
Right!
« Reply #28 on: April 30, 2012, 04:19:05 AM »
I think it was put up at 0.6mm before but 1/4"=6.35mm.
I used a 125 gy6 stator, and This cdi/coil. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItemVersion&item=160781981964&view=all&tid=744122197006
It jumps about .75" It's not powerful (I got lit up a few times setting it up) but it jumps. The kick start never fired it so never worked. One kick now, maybe two when cold. This is all on that gy6 engine...
