Author Topic: Possible to access air/fuel mix screw on Agility 125 with only seat well out?  (Read 9862 times)
AgilityOnAnRV
Carb intake
Is that the same as the intake manifold? If so, I'll be replacing that on Thursday or Friday.
No. The other side of the carb!
AgilityOnAnRV
PROBLEM!!!!
I replaced the carb diaphragm and the scooter started fine. I then tried replacing the intake manifold. I took off the old manifold and everything looked fine but decided to try putting on the new one anyway. It didn't fit (couldn't screw down the two nuts all the way to fully secure it) so I put the old one back on. Now the scoot won't start!!! It cranks but doesn't go anywhere. All hoses appear to be in place just fine. I'll try taking off the manifold and putting it back on, but this definitely sucks.
Help, please!
AgilityOnAnRV
PROBLEM!!!!
Help, please!
And... in one of the more embarrassing moments of my life I admit that I just spent 2.5 hours ridiculously frustrated, only to figure out that I had accidentally hit the kill switch at some point prior. A mechanic friend reassured me that it's a mistake that everyone makes precisely one time in their life, but man, what an emotional roller coaster of a night!
Time to go check this thing out on the road.
AgilityOnAnRV
The latest news:
- The scooter runs just fine and it seems as though it doesn't sputter / consider dying at stops anymore. The ride wasn't terribly long so it's possible that it was just kidding about this :-)
- The surging issue is still there and it's now occurring at WOT / a bit under WOT around 45 MPH, whereas previously it only occurred at WOT above 50 MPH. A friend who knows bike engines should be coming over sometime in the next few days and hopefully we can figure something out. I'm guessing that it is related to the intake manifold, though, if that's the main thing that I played around with today (other than the diaphragm).
juice
Im glad you got it running again , running more of the seafoam and fresh gas through your system might still help out your issues . Good luck and enjoy your scoot !   P.S. I have had the same accident with the kill switch , it happens more often than you would think .
« Last Edit: May 12, 2012, 04:32:06 PM by juice »
